<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-z06-gm-techlink-hard-shifting-into-1st-gear-or-reverse-1379.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</guid>
										<title>2014 - 2018 Corvette:  Service Bulletin:  #PIP5248D: Stalling Shudder And/or Hard   shifting Into 1st Gear Or Reverse Vibration On launch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-fuel-line-pulsation-sound-1361.html</guid>
										<title>2014 - 2017 Corvette:  GM TechLink:  Fuel Line Pulsation Sound</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-fuel-line-pulsation-sound-1361.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-15-06-01-002k-engine-misfire-tick-noise-malfunction-indicator-lamp-mil-illuminated-dtc-p0300-set-dec-17-2020-1479.html</guid>
										<title>2014 - 2019 Corvette: Service Bulletin: #15-06-01-002K: Engine Misfire/Tick Noise, Malfunction Indicator Lamp (MIL) Illuminated - DTC P0300 Set - (Dec 17, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-15-06-01-002k-engine-misfire-tick-noise-malfunction-indicator-lamp-mil-illuminated-dtc-p0300-set-dec-17-2020-1479.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-fuel-injector-and-oil-ring-seal-replacement-1011.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink:  Fuel Injector and Oil Ring Seal Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-fuel-injector-and-oil-ring-seal-replacement-1011.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-oil-change-information-for-chevrolet-corvette-1397.html</guid>
										<title>2014 - 2019 Corvette:  Service Bulletin: Oil Change Information for Chevrolet Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-oil-change-information-for-chevrolet-corvette-1397.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-harsh-shift-and-rough-idle-conditions-1420.html</guid>
										<title>2014 - 2017 Corvette: GM TechLink: Harsh Shift and Rough Idle Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-harsh-shift-and-rough-idle-conditions-1420.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-pip5498-ses-lamp-p050d-p0300-setting-on-a-cold-start-1364.html</guid>
										<title>2016 - 2017 Corvette:  Service Bulletin: #PIP5498: SES Lamp P050D P0300 Setting On A Cold Start</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-pip5498-ses-lamp-p050d-p0300-setting-on-a-cold-start-1364.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-18-na-285-information-on-slight-movement-in-park-at-ignition-on-and-vehicle-start-up-and-or-during-a-remote-vehicle-start-event-jan-22-2021-1486.html</guid>
										<title>2015 - 2019 Corvette: Service Bulletin: #18-NA-285: Information on Slight Movement in Park at Ignition On and Vehicle Start Up and/or During a Remote Vehicle Start Event - (Jan 22, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-18-na-285-information-on-slight-movement-in-park-at-ignition-on-and-vehicle-start-up-and-or-during-a-remote-vehicle-start-event-jan-22-2021-1486.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-service-bulletin-21-na-109-diagnostic-information-on-engine-vibration-may-3-2021-1510.html</guid>
										<title>2016 - 2019 Corvette: Service Bulletin: #21-NA-109: Diagnostic Information on Engine Vibration - (May 3, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-service-bulletin-21-na-109-diagnostic-information-on-engine-vibration-may-3-2021-1510.html</link>
