<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2017-corvette-service-bulletin-pic6162b-questions-regarding-the-use-of-high-performance-high-temperature-brake-fluid-during-track-use-1372.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-information-on-visual-brake-rotor-surface-cracking-201.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Information on Visual Brake Rotor Surface Cracking</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-information-on-visual-brake-rotor-surface-cracking-201.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-recall-hydraulic-brake-line-leak-359.html</guid>
										<title>2005 Corvette: Recall: Hydraulic Brake Line Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-recall-hydraulic-brake-line-leak-359.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-gm-techlink-brake-pads-356.html</guid>
										<title>2006 Corvette: GM TechLink: Brake Pads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-gm-techlink-brake-pads-356.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-techlink-article-front-brake-rotor-cooling-rings-20.html</guid>
										<title>2014 Corvette: Techlink Article: Front Brake Rotor Cooling Rings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-techlink-article-front-brake-rotor-cooling-rings-20.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-brake-noise-on-initial-brake-apply-10.html</guid>
										<title>2014 Corvette: GM TechLink Article: Brake Noise on Initial Brake Apply</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-brake-noise-on-initial-brake-apply-10.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-z06-gm-techlink-brake-pad-wear-sensor-harness-1124.html</guid>
										<title>2015 Corvette Z06:  GM TechLink:  Brake Pad Wear Sensor Harness</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-z06-gm-techlink-brake-pad-wear-sensor-harness-1124.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2011-corvette-gm-techlink-aftermarket-braided-stainless-steel-brake-lines-68.html</guid>
										<title>1997 - 2011 Corvette:  GM TechLink:  Aftermarket Braided Stainless Steel Brake Lines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2011-corvette-gm-techlink-aftermarket-braided-stainless-steel-brake-lines-68.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-cross-drilled-rotors-357.html</guid>
										<title>2005 Corvette: GM TechLink: Cross-Drilled Rotors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-cross-drilled-rotors-357.html</link>
