<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-information-hydra-matic-6l80-six-speed-automatic-car-truck-transmission-137.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-manual-transmission-operating-characteristics-195.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Manual Transmission Operating Characteristics</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-manual-transmission-operating-characteristics-195.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-bulletin-clutch-pedal-effort-complaint-166.html</guid>
										<title>2008 Corvette: Service Bulletin:  Clutch Pedal Effort Complaint</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-bulletin-clutch-pedal-effort-complaint-166.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-new-product-announcement-hydra-matic-6l80-automatic-transmission-204.html</guid>
										<title>2006 Corvette: Service Bulletin: New Product Announcement -- Hydra-Matic 6L80 Automatic Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-new-product-announcement-hydra-matic-6l80-automatic-transmission-204.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-customer-satisfaction-program-engine-flywheel-clutch-interference-327.html</guid>
										<title>2006 Corvette: Customer Satisfaction Program: Engine Flywheel/Clutch Interference</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-diagnosis-of-cracked-or-broken-transmission-case-271.html</guid>
										<title>2006 Corvette: Service Bulletin:  Diagnosis of Cracked or Broken Transmission Case</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-diagnosis-of-cracked-or-broken-transmission-case-271.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2012-corvette-service-bulletin-pi0773-diagnostic-tips-for-dtc-p0796-slip-or-no-4th-5th-or-6th-gear-jul-25-2012-1336.html</guid>
										<title>2006 - 2012 Corvette: Service Bulletin: #PI0773: Diagnostic Tips for DTC P0796, Slip or No 4th, 5th or 6th Gear - (Jul 25, 2012)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2012-corvette-service-bulletin-pi0773-diagnostic-tips-for-dtc-p0796-slip-or-no-4th-5th-or-6th-gear-jul-25-2012-1336.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-mis-machined-transmission-countershaft-snap-352.html</guid>
										<title>2005 Corvette: Service Bulletin: Mis-Machined Transmission Countershaft Snap</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-mis-machined-transmission-countershaft-snap-352.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-information-on-driveline-clunk-noise-when-shifting-between-park-and-drive-park-and-reverse-or-drive-and-reverse-214.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Information on Driveline Clunk Noise When Shifting Between PARK and DRIVE, PARK and REVERSE or DRIVE and REVERSE</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-information-on-driveline-clunk-noise-when-shifting-between-park-and-drive-park-and-reverse-or-drive-and-reverse-214.html</link>
