<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-gm-techlink-supercharger-idler-pulley-sounds-1362.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-z06-special-coverage-adjustment-n202302720-on-track-performance-engine-overheating-1488.html</guid>
										<title>2015 - 2018 Corvette Z06: Special Coverage Adjustment - N202302720 On Track Performance Engine Overheating</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-z06-special-coverage-adjustment-n202302720-on-track-performance-engine-overheating-1488.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5290e-oil-change-information-for-2014-2018-chevrolet-corvette-us-only-1359.html</guid>
										<title>2014 - 2018 Corvette: Service Bulletin: #PIP5290E: Oil Change information For 2014 - 2018 Chevrolet Corvette (US Only)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5290e-oil-change-information-for-2014-2018-chevrolet-corvette-us-only-1359.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-surge-misfire-feeling-sensation-during-highway-steady-state-driving-jun-6-2016-1272.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin:  Surge Misfire Feeling Sensation During Highway Steady State Driving - (Jun 6, 2016)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-surge-misfire-feeling-sensation-during-highway-steady-state-driving-jun-6-2016-1272.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-z06-service-bulletin-pip5455a-lt4-supercharger-belt-tensioner-noise-with-a-light-tip-in-afm-1357.html</guid>
										<title>2015 - 2017 Corvette Z06: Service Bulletin: #PIP5455A: LT4 Supercharger Belt Tensioner Noise with A light Tip In AFM</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-z06-service-bulletin-pip5455a-lt4-supercharger-belt-tensioner-noise-with-a-light-tip-in-afm-1357.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-service-bulletin-pip5492-scraping-or-moan-noise-heard-during-engine-idle-1356.html</guid>
										<title>2017 Corvette Z06: Service Bulletin: #PIP5492: Scraping or Moan Noise heard During Engine Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-service-bulletin-pip5492-scraping-or-moan-noise-heard-during-engine-idle-1356.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-gm-techlink-warble-sound-from-rear-of-vehicle-1435.html</guid>
										<title>2014 - 2019 Corvette: GM TechLink:  Warble Sound from Rear of Vehicle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-gm-techlink-warble-sound-from-rear-of-vehicle-1435.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-oil-change-information-for-2014-2017-chevrolet-corvette-1311.html</guid>
										<title>2014 - 2017 Corvette:  Service Bulletin: Oil Change information For 2014 - 2017 Chevrolet Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-oil-change-information-for-2014-2017-chevrolet-corvette-1311.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</guid>
										<title>2014 - 2018 Corvette:  Service Bulletin:  #PIP5248D: Stalling Shudder And/or Hard   shifting Into 1st Gear Or Reverse Vibration On launch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-pip5498b-ses-lamp-p050d-p0300-setting-on-a-cold-start-and-or-a-run-rough-warm-with-no-codes-1378.html</guid>
										<title>2016 - 2017 Corvette:  Service Bulletin: #PIP5498B: SES Lamp P050D P0300 Setting On A Cold Start And/Or a Run Rough Warm with No codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-pip5498b-ses-lamp-p050d-p0300-setting-on-a-cold-start-and-or-a-run-rough-warm-with-no-codes-1378.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-15-na-002-information-on-fuel-odor-and-or-fuel-leaks-from-underhood-sidi-pipes-between-high-pressure-pump-and-fuel-rails-1375.html</guid>
										<title>2015 - 2017 Corvette:  Service Bulletin: #15-NA-002: Information on Fuel Odor and/or Fuel Leaks from Underhood SIDI Pipes Between High Pressure Pump and Fuel Rails</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-15-na-002-information-on-fuel-odor-and-or-fuel-leaks-from-underhood-sidi-pipes-between-high-pressure-pump-and-fuel-rails-1375.html</link>
