<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-fuel-line-pulsation-sound-1361.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-z06-zr1-service-bulletin-17-na-408-information-on-charge-air-cooler-cac-draining-and-filling-dtc-p0300-set-oct-9-2020-1454.html</guid>
										<title>2016 - 2019 Corvette Z06 ZR1: Service Bulletin: #17-NA-408: Information on Charge Air Cooler (CAC) Draining and Filling - DTC P0300 Set - (Oct 9, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-z06-zr1-service-bulletin-17-na-408-information-on-charge-air-cooler-cac-draining-and-filling-dtc-p0300-set-oct-9-2020-1454.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-setting-the-timing-on-gen-5-v6-and-v8-engines-1405.html</guid>
										<title>2016 - 2019 Corvette: GM TechLink: Setting the Timing on Gen 5 V6 and V8 Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-setting-the-timing-on-gen-5-v6-and-v8-engines-1405.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-gm-techlink-air-filter-box-seal-leak-1269.html</guid>
										<title>2014 - 2016 Corvette:  GM TechLink:  Air Filter Box Seal Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-gm-techlink-air-filter-box-seal-leak-1269.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-service-bulletin-20-na-200-diagnostic-tip-for-malfunction-indicator-lamp-mil-illuminated-dtc-p0172-and-or-p0175-set-1447.html</guid>
										<title>2016 - 2019 Corvette: Service Bulletin: #20-NA-200: Diagnostic Tip for Malfunction Indicator Lamp (MIL) Illuminated - DTC P0172 and/or P0175 Set</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-stingray-and-z06-gm-techlink-v8-engine-surge-sensation-during-highway-driving-1419.html</guid>
										<title>2014 - 2016 Corvette Stingray and Z06: GM TechLink: V8 Engine Surge Sensation during Highway Driving</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-stingray-and-z06-gm-techlink-v8-engine-surge-sensation-during-highway-driving-1419.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-article-extended-cold-crank-with-direct-injected-engines-8.html</guid>
										<title>2014 - 2015 Corvette: GM TechLink Article: Extended Cold Crank with Direct Injected Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-article-extended-cold-crank-with-direct-injected-engines-8.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin:  Code P06DD No Or Low Oil Pressure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-16009-primary-tank-inlet-check-valve-fuel-and-vapor-leaks-1312.html</guid>
										<title>2014 - 2015 Corvette:  Service Bulletin:  16009 Primary Tank Inlet Check Valve Fuel and Vapor Leaks</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-16009-primary-tank-inlet-check-valve-fuel-and-vapor-leaks-1312.html</link>
