<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5290e-oil-change-information-for-2014-2018-chevrolet-corvette-us-only-1359.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-pip5498-ses-lamp-p050d-p0300-setting-on-a-cold-start-1364.html</guid>
										<title>2016 - 2017 Corvette:  Service Bulletin: #PIP5498: SES Lamp P050D P0300 Setting On A Cold Start</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-pip5498-ses-lamp-p050d-p0300-setting-on-a-cold-start-1364.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-engine-oil-capacities-1030.html</guid>
										<title>2014 - 2015 Corvette:  Engine Oil Capacities</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-engine-oil-capacities-1030.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin:  Code P06DD No Or Low Oil Pressure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-z06-gm-techlink-hard-shifting-into-1st-gear-or-reverse-1379.html</guid>
										<title>2015 - 2018 Corvette Z06:  GM TechLink:  Hard Shifting into 1st Gear or Reverse</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-z06-gm-techlink-hard-shifting-into-1st-gear-or-reverse-1379.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-gm-techlink-air-filter-box-seal-leak-1269.html</guid>
										<title>2014 - 2016 Corvette:  GM TechLink:  Air Filter Box Seal Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-gm-techlink-air-filter-box-seal-leak-1269.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-service-bulletin-pip5492-scraping-or-moan-noise-heard-during-engine-idle-1356.html</guid>
										<title>2017 Corvette Z06: Service Bulletin: #PIP5492: Scraping or Moan Noise heard During Engine Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-service-bulletin-pip5492-scraping-or-moan-noise-heard-during-engine-idle-1356.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-break-in-oil-change-for-corvette-included-in-chevrolet-complete-care-program-1122.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink:  Break-In Oil Change for Corvette Included in Chevrolet Complete Care Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-break-in-oil-change-for-corvette-included-in-chevrolet-complete-care-program-1122.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-service-bulletin-pip5485-supercharger-whine-noise-mar-14-2017-1334.html</guid>
										<title>2017 Corvette Z06:  Service Bulletin:  #PIP5485: Supercharger Whine Noise - (Mar 14, 2017)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-service-bulletin-pip5485-supercharger-whine-noise-mar-14-2017-1334.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-service-bulletin-20-na-200-diagnostic-tip-for-malfunction-indicator-lamp-mil-illuminated-dtc-p0172-and-or-p0175-set-1447.html</guid>
										<title>2016 - 2019 Corvette: Service Bulletin: #20-NA-200: Diagnostic Tip for Malfunction Indicator Lamp (MIL) Illuminated - DTC P0172 and/or P0175 Set</title>
