<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-16-na-404-harsh-shift-delayed-shift-unwanted-downshift-transmission-stuck-in-one-gear-erratic-shifting-hesitation-or-have-a-malfunction-indicator-lamp-mil-illuminated-1353.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-recall-low-rear-differential-fluid-level-847.html</guid>
										<title>2014 Corvette: Recall: Low Rear Differential Fluid Level</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-recall-low-rear-differential-fluid-level-847.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-diagnostic-tip-for-harsh-shifts-after-mileage-accumulation-without-previous-transmission-repairs-and-or-calibration-updates-1286.html</guid>
										<title>2015 - 2016 Corvette:  Service Bulletin: Diagnostic Tip for Harsh Shifts After Mileage Accumulation Without Previous Transmission Repairs and/or Calibration Updates</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-diagnostic-tip-for-harsh-shifts-after-mileage-accumulation-without-previous-transmission-repairs-and-or-calibration-updates-1286.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-shift-concerns-on-8-speed-transmissions-1531.html</guid>
										<title>2015 - 2018 Corvette: Shift Concerns on 8-Speed Transmissions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-shift-concerns-on-8-speed-transmissions-1531.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-gm-techlink-3rd-gear-condition-on-manual-transmission-1317.html</guid>
										<title>2017 Corvette:  GM TechLink:  3rd Gear Condition on Manual Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-gm-techlink-3rd-gear-condition-on-manual-transmission-1317.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-16-na-014-delayed-engagement-after-sitting-with-engine-off-1290.html</guid>
										<title>2015 - 2016 Corvette: Service Bulletin: #16-NA-014: Delayed Engagement After Sitting With Engine Off</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-16-na-014-delayed-engagement-after-sitting-with-engine-off-1290.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-techlink-article-corvette-driveline-support-alignment-22.html</guid>
										<title>2014 Corvette: Techlink Article: Corvette Driveline Support Alignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-techlink-article-corvette-driveline-support-alignment-22.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-16-na-364-delayed-engagement-after-sitting-with-engine-off-clutch-slow-to-fill-1373.html</guid>
										<title>2015 - 2017 Corvette: Service Bulletin: #16-NA-364: Delayed Engagement After Sitting With Engine Off - Clutch Slow to Fill</title>
