<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2017-corvette-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-1344.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-engine-misfire-tick-noise-malfunction-indicator-lamp-mil-on-dtc-p0300-set-1291.html</guid>
										<title>2014 - 2016 Corvette: Service Bulletin: Engine Misfire/Tick Noise, Malfunction Indicator Lamp (MIL) On, DTC P0300 Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-engine-misfire-tick-noise-malfunction-indicator-lamp-mil-on-dtc-p0300-set-1291.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-axle-vent-noise-329.html</guid>
										<title>2005 Corvette: GM TechLink: Axle Vent Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-axle-vent-noise-329.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2013-corvette-gm-techlink-low-oil-pressure-on-v8-engines-1233.html</guid>
										<title>2007 - 2013 Corvette:  GM TechLink:  Low Oil Pressure on V8 Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2013-corvette-gm-techlink-low-oil-pressure-on-v8-engines-1233.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2005-corvette-gm-techlink-fuel-line-quick-connectors-387.html</guid>
										<title>2004 - 2005 Corvette: GM TechLink: Fuel Line Quick Connectors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2005-corvette-gm-techlink-fuel-line-quick-connectors-387.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-news-rough-idle-or-vibration-960.html</guid>
										<title>2014 - 2015 Corvette:  Service News:  Rough Idle or Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-news-rough-idle-or-vibration-960.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-service-bulletin-20-na-200-diagnostic-tip-for-malfunction-indicator-lamp-mil-illuminated-dtc-p0172-and-or-p0175-set-1447.html</guid>
										<title>2016 - 2019 Corvette: Service Bulletin: #20-NA-200: Diagnostic Tip for Malfunction Indicator Lamp (MIL) Illuminated - DTC P0172 and/or P0175 Set</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-gasoline-engine-oil-requirements-333.html</guid>
										<title>2005 Corvette: GM TechLink: Gasoline Engine Oil Requirements</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-gasoline-engine-oil-requirements-333.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</guid>
										<title>2014 - 2018 Corvette:  Service Bulletin:  #PIP5248D: Stalling Shudder And/or Hard   shifting Into 1st Gear Or Reverse Vibration On launch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</link>
