<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-17098-service-update-8-speed-transmission-check-engine-light-mar-23-2017-1343.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-pip5437b-8l45-8l90-diagnostic-tips-for-harsh-shifts-and-delayed-or-harsh-garage-shift-engagements-1365.html</guid>
										<title>2015 - 2017 Corvette: Service Bulletin: #PIP5437B: 8L45 8L90 Diagnostic Tips for Harsh Shifts and Delayed or Harsh Garage Shift Engagements</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-pip5437b-8l45-8l90-diagnostic-tips-for-harsh-shifts-and-delayed-or-harsh-garage-shift-engagements-1365.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-18-na-285-information-on-slight-movement-in-park-at-ignition-on-and-vehicle-start-up-and-or-during-a-remote-vehicle-start-event-jan-22-2021-1486.html</guid>
										<title>2015 - 2019 Corvette: Service Bulletin: #18-NA-285: Information on Slight Movement in Park at Ignition On and Vehicle Start Up and/or During a Remote Vehicle Start Event - (Jan 22, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-18-na-285-information-on-slight-movement-in-park-at-ignition-on-and-vehicle-start-up-and-or-during-a-remote-vehicle-start-event-jan-22-2021-1486.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-diagnostic-tip-for-harsh-shifts-after-mileage-accumulation-without-previous-transmission-repairs-and-or-calibration-updates-1286.html</guid>
										<title>2015 - 2016 Corvette:  Service Bulletin: Diagnostic Tip for Harsh Shifts After Mileage Accumulation Without Previous Transmission Repairs and/or Calibration Updates</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-diagnostic-tip-for-harsh-shifts-after-mileage-accumulation-without-previous-transmission-repairs-and-or-calibration-updates-1286.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-recall-low-rear-differential-fluid-level-847.html</guid>
										<title>2014 Corvette: Recall: Low Rear Differential Fluid Level</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-recall-low-rear-differential-fluid-level-847.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-16-na-361-information-on-transmission-harsh-1-2-shift-upon-first-start-up-shift-of-the-day-under-light-throttle-1354.html</guid>
										<title>2015 - 2019 Corvette: Service Bulletin: #16-NA-361: Information on Transmission Harsh 1-2 Shift Upon First Start Up/Shift of the Day Under Light Throttle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-16-na-361-information-on-transmission-harsh-1-2-shift-upon-first-start-up-shift-of-the-day-under-light-throttle-1354.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-gm-techlink-diagnostic-tips-for-harsh-shifting-transmission-conditions-1380.html</guid>
										<title>2015 - 2017 Corvette: GM TechLink:  Diagnostic Tips for Harsh Shifting Transmission Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-gm-techlink-diagnostic-tips-for-harsh-shifting-transmission-conditions-1380.html</link>
