										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-heat-shielding-132.html</guid>
										<title>1973 Corvette: Service Bulletin:  Exhaust Manifold Heat Shielding</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-heat-shielding-132.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-product-safety-campaign-fuel-tank-return-line-tube-fitting-leakage-1241.html</guid>
										<title>1974 Corvette:  Product Safety Campaign:  Fuel Tank Return Line Tube Fitting Leakage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-product-safety-campaign-fuel-tank-return-line-tube-fitting-leakage-1241.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-features-sheet-chevrolet-l88-engine-assembly-features-1177.html</guid>
										<title>1968 Corvette:  Features Sheet:  Chevrolet L88 Engine Assembly Features</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-features-sheet-chevrolet-l88-engine-assembly-features-1177.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-headlamp-opening-interference-696.html</guid>
										<title>1969 Corvette: Service Bulletin: Headlamp Opening Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-headlamp-opening-interference-696.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-inter-organization-letter-water-leaks-1968-corvette-aero-coupe-and-convertible-supplement-to-a-i-68-11-1112.html</guid>
										<title>1968 Corvette: Inter-Organization Letter:  Water Leaks - 1968 Corvette Aero-Coupe and Convertible Supplement to A.I. 68-11</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-inter-organization-letter-water-leaks-1968-corvette-aero-coupe-and-convertible-supplement-to-a-i-68-11-1112.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-news-red-idle-mixture-screw-caps-822.html</guid>
										<title>1973 Corvette: Service News: Red Idle Mixture Screw Caps</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-news-red-idle-mixture-screw-caps-822.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-1982-corvette-service-bulletin-viton-accelerator-pumps-current-and-past-models-equipped-with-dual-and-quadrajets-1036.html</guid>
										<title>1975 - 1982 Corvette:  Service Bulletin:  Viton Accelerator Pumps - Current and Past Models Equipped with Dual and Quadrajets</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-1982-corvette-service-bulletin-viton-accelerator-pumps-current-and-past-models-equipped-with-dual-and-quadrajets-1036.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-1982-corvette-service-news-differential-side-bearing-removal-936.html</guid>
										<title>1980 - 1982 Corvette:  Service News:  Differential Side Bearing Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-1982-corvette-service-news-differential-side-bearing-removal-936.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-engineering-memo-window-service-update-1227.html</guid>
										<title>1968 Corvette:  Chevrolet Engineering Memo:  Window Service Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-engineering-memo-window-service-update-1227.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-switch-protective-grease-1104.html</guid>
										<title>1977 Corvette:  Service Bulletin:  Anti-Theft Alarm Switch - Protective Grease</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-switch-protective-grease-1104.html</link>
