										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-language-change-for-onstar-system-u-s-only-197.html</guid>
										<title>2006 Corvette: Service Bulletin: Language Change for OnStar System (U.S. Only)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-language-change-for-onstar-system-u-s-only-197.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-horn-system-232.html</guid>
										<title>2006 Corvette: Electrical Schematic:  Horn System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-horn-system-232.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-instrument-panel-i-p-body-and-general-wiring-harness-repair-199.html</guid>
										<title>2007 Corvette: Service Bulletin: Instrument Panel (I/P), Body and General Wiring Harness Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-instrument-panel-i-p-body-and-general-wiring-harness-repair-199.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-keyless-ignition-system-information-346.html</guid>
										<title>2005 Corvette: GM TechLink: Keyless Ignition System Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-keyless-ignition-system-information-346.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-cold-tire-characteristics-of-gm-original-equipment-tires-272.html</guid>
										<title>2006 Corvette: Service Bulletin:  Cold Tire Characteristics of GM Original Equipment Tires</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-cold-tire-characteristics-of-gm-original-equipment-tires-272.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-engine-controls-207.html</guid>
										<title>2006 Corvette: Electrical Schematic: Engine Controls</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-engine-controls-207.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-malfunction-indicator-lamp-mil-diagnostic-trouble-code-dtc-p0833-cruise-control-inoperative-adjust-clutch-release-switch-344.html</guid>
										<title>2005 Corvette: Service Bulletin: Malfunction Indicator Lamp (MIL), Diagnostic Trouble Code (DTC) P0833, Cruise Control Inoperative (Adjust Clutch Release Switch)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-malfunction-indicator-lamp-mil-diagnostic-trouble-code-dtc-p0833-cruise-control-inoperative-adjust-clutch-release-switch-344.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-information-transmitter-programming-domestic-and-japan-135.html</guid>
										<title>2006 Corvette: Service Information: Transmitter Programming (Domestic and Japan)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-information-transmitter-programming-domestic-and-japan-135.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-power-distribution-260.html</guid>
										<title>2006 Corvette:  Electrical Schematic:  Power Distribution</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-power-distribution-260.html</link>
