<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-service-bulletin-pic5049a-fuel-tank-hard-to-fill-or-displays-1-2-tank-after-filling-oct-22-2012-1332.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2008-corvette-service-campaign-unwanted-repeat-calls-to-onstar-13.html</guid>
										<title>2004 - 2008 Corvette: Service Campaign: Unwanted Repeat Calls to OnStar</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2008-corvette-service-campaign-unwanted-repeat-calls-to-onstar-13.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-poor-and-or-no-radio-reception-intermittent-static-on-fm-with-navigational-radio-system-update-radio-software-340.html</guid>
										<title>2005 Corvette: Service Bulletin: Poor and/or No Radio Reception, Intermittent Static on FM with Navigational Radio System (Update Radio Software)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-poor-and-or-no-radio-reception-intermittent-static-on-fm-with-navigational-radio-system-update-radio-software-340.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-horn-system-232.html</guid>
										<title>2006 Corvette: Electrical Schematic:  Horn System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-horn-system-232.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-actual-outside-temperature-does-not-match-temperature-reading-on-inter-display-normal-operating-characteristic-341.html</guid>
										<title>2005 Corvette: Service Bulletin: Actual Outside Temperature Does Not Match Temperature Reading On Inter Display - Normal Operating Characteristic</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-actual-outside-temperature-does-not-match-temperature-reading-on-inter-display-normal-operating-characteristic-341.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2016-corvette-15521-customer-advisory-letter-side-door-release-operation-phase-2-mailing-1268.html</guid>
										<title>2005 - 2016 Corvette: 15521 - Customer Advisory Letter - Side Door Release Operation - Phase 2 Mailing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2016-corvette-15521-customer-advisory-letter-side-door-release-operation-phase-2-mailing-1268.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-service-bulletin-stabilitrak-active-handling-light-on-service-stabilitrak-active-handling-message-on-dic-152.html</guid>
										<title>2005 - 2008: Service Bulletin:  Stabilitrak/Active Handling Light On, Service Stabilitrak/Active Handling Message on DIC</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-diagnostic-trouble-codes-220.html</guid>
										<title>2006 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-diagnostic-trouble-codes-220.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-information-transmitter-programming-domestic-and-japan-135.html</guid>
										<title>2006 Corvette: Service Information: Transmitter Programming (Domestic and Japan)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-information-transmitter-programming-domestic-and-japan-135.html</link>
