										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-setting-the-clock-radio-337.html</guid>
										<title>2005 Corvette: GM TechLink: Setting the Clock Radio</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-setting-the-clock-radio-337.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-customer-satisfaction-program-keyless-access-system-inoperative-168.html</guid>
										<title>2008 Corvette: Customer Satisfaction Program: Keyless Access System Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-customer-satisfaction-program-keyless-access-system-inoperative-168.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-corvette-personal-audio-link-pal-installation-for-vehicles-equipped-with-factory-navigation-u3u-75.html</guid>
										<title>2006 - 2013 Corvette:  Corvette Personal Audio Link (PAL) Installation for Vehicles Equipped with Factory Navigation (U3U)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-corvette-personal-audio-link-pal-installation-for-vehicles-equipped-with-factory-navigation-u3u-75.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-trip-odometer-operation-98.html</guid>
										<title>2005 - 2008 Corvette: GM TechLink: Trip Odometer Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-trip-odometer-operation-98.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-exterior-lamps-circuit-206.html</guid>
										<title>2006 Corvette: Electrical Schematic: Exterior Lamps Circuit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-exterior-lamps-circuit-206.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-automatic-ac-system-210.html</guid>
										<title>2006 Corvette: Electrical Schematic: Automatic AC System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-automatic-ac-system-210.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-low-or-completely-discharged-battery-338.html</guid>
										<title>2005 Corvette: GM TechLink: Low or Completely Discharged Battery</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-low-or-completely-discharged-battery-338.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-power-distribution-260.html</guid>
										<title>2006 Corvette:  Electrical Schematic:  Power Distribution</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-power-distribution-260.html</link>
