										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-z06-service-bulletin-18096-brake-deflector-for-street-use-not-installed-1400.html</guid>
										<title>2019 Corvette Z06:  Service Bulletin: 18096 Brake Deflector for Street Use Not Installed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-z06-service-bulletin-18096-brake-deflector-for-street-use-not-installed-1400.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2017-corvette-service-bulletin-pic6162b-questions-regarding-the-use-of-high-performance-high-temperature-brake-fluid-during-track-use-1372.html</guid>
										<title>2009 - 2017 Corvette: Service Bulletin: #PIC6162B: Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2017-corvette-service-bulletin-pic6162b-questions-regarding-the-use-of-high-performance-high-temperature-brake-fluid-during-track-use-1372.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pic6083a-normal-characteristic-vehicle-unable-to-move-after-being-parked-for-an-extended-period-of-time-mar-27-2017-1345.html</guid>
										<title>2014 - 2017 Corvette: Service Bulletin: #PIC6083A: Normal Characteristic - Vehicle Unable To Move After Being Parked For An Extended Period Of Time - (Mar 27, 2017)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pic6083a-normal-characteristic-vehicle-unable-to-move-after-being-parked-for-an-extended-period-of-time-mar-27-2017-1345.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-brake-noise-on-initial-brake-apply-10.html</guid>
										<title>2014 Corvette: GM TechLink Article: Brake Noise on Initial Brake Apply</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-brake-noise-on-initial-brake-apply-10.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-17267-service-update-brake-wear-indicator-not-functioning-properly-1374.html</guid>
										<title>2016 - 2017 Corvette: Service Bulletin: #17267: Service Update - Brake Wear Indicator Not Functioning Properly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-17267-service-update-brake-wear-indicator-not-functioning-properly-1374.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-corvette-brake-service-tips-1513.html</guid>
										<title>2020 - 2021 Corvette: GM TechLink: Corvette Brake Service Tips</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-corvette-brake-service-tips-1513.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pic6429-addressing-customer-concerns-on-brake-noises-jan-20-2021-1484.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #PIC6429: Addressing Customer Concerns on Brake Noises - (Jan 20, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pic6429-addressing-customer-concerns-on-brake-noises-jan-20-2021-1484.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-weather-conditions-effect-on-high-performance-brake-components-1199.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink: Weather Conditions` Effect on High-Performance Brake Components</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-weather-conditions-effect-on-high-performance-brake-components-1199.html</link>
