<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-recall-16038-transmission-oil-cooler-line-in-contact-with-body-stud-1322.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-16-na-014-delayed-engagement-after-sitting-with-engine-off-1290.html</guid>
										<title>2015 - 2016 Corvette: Service Bulletin: #16-NA-014: Delayed Engagement After Sitting With Engine Off</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-16-na-014-delayed-engagement-after-sitting-with-engine-off-1290.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-pip5447b-p3400-setting-with-8-speed-only-apr-4-2017-1352.html</guid>
										<title>2016 - 2017 Corvette: Service Bulletin: #PIP5447B: P3400 setting with 8 speed only - (Apr 4, 2017)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-pip5447b-p3400-setting-with-8-speed-only-apr-4-2017-1352.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-gm-techlink-3rd-gear-condition-on-manual-transmission-1317.html</guid>
										<title>2017 Corvette:  GM TechLink:  3rd Gear Condition on Manual Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-gm-techlink-3rd-gear-condition-on-manual-transmission-1317.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-diagnostic-tip-for-harsh-shifts-after-mileage-accumulation-without-previous-transmission-repairs-and-or-calibration-updates-1286.html</guid>
										<title>2015 - 2016 Corvette:  Service Bulletin: Diagnostic Tip for Harsh Shifts After Mileage Accumulation Without Previous Transmission Repairs and/or Calibration Updates</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-diagnostic-tip-for-harsh-shifts-after-mileage-accumulation-without-previous-transmission-repairs-and-or-calibration-updates-1286.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-shake-and-or-shudder-during-light-throttle-acceleration-between-25-and-80-mph-40-and-128-km-h-at-a-steady-state-1324.html</guid>
										<title>2015 - 2017 Corvette:  Service Bulletin:  Shake and/or Shudder During Light Throttle Acceleration Between 25 and 80 MPH (40 and 128 KM/H) at a Steady State</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-shake-and-or-shudder-during-light-throttle-acceleration-between-25-and-80-mph-40-and-128-km-h-at-a-steady-state-1324.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2018-2019-corvette-gm-techlink-delayed-transmission-engagement-1448.html</guid>
										<title>2018 - 2019 Corvette: GM TechLink: Delayed Transmission Engagement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2018-2019-corvette-gm-techlink-delayed-transmission-engagement-1448.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-all-new-8l90-8-speed-automatic-transmission-1197.html</guid>
										<title>2015 Corvette:  GM TechLink:  All New 8L90 8-Speed Automatic Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-all-new-8l90-8-speed-automatic-transmission-1197.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-techlink-article-corvette-driveline-support-alignment-22.html</guid>
										<title>2014 Corvette: Techlink Article: Corvette Driveline Support Alignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-techlink-article-corvette-driveline-support-alignment-22.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-press-release-new-8-speed-enables-quicker-more-efficient-corvette-869.html</guid>
										<title>2015 Corvette:  GM Press Release:  New 8-Speed Enables Quicker, More Efficient Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-press-release-new-8-speed-enables-quicker-more-efficient-corvette-869.html</link>
