<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-electrical-features-information-1321.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2004-corvette-service-bulletin-twilight-sentinel-automatic-headlamp-control-not-functioning-correctly-or-is-inoperative-218.html</guid>
										<title>2000 - 2004 Corvette: Service Bulletin: Twilight Sentinel/Automatic Headlamp Control Not Functioning Correctly or is Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2004-corvette-service-bulletin-twilight-sentinel-automatic-headlamp-control-not-functioning-correctly-or-is-inoperative-218.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-inoperative-remote-keyless-entry-system-and-or-tire-pressure-monitor-system-424.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Inoperative Remote Keyless Entry System and/or Tire Pressure Monitor System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-inoperative-remote-keyless-entry-system-and-or-tire-pressure-monitor-system-424.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-news-corvette-illuminated-check-gauges-light-882.html</guid>
										<title>1997 - 1999 Corvette:  Service News:  Corvette Illuminated Check Gauges Light</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-news-corvette-illuminated-check-gauges-light-882.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-misfire-dtcs-and-catalytic-converter-damage-due-to-installation-of-alarm-systems-419.html</guid>
										<title>1997 - 2003 Corvette: Service Bulletin: Misfire DTCs and Catalytic Converter Damage Due to Installation of Alarm Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-misfire-dtcs-and-catalytic-converter-damage-due-to-installation-of-alarm-systems-419.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-product-campaign-pcm-calibration-reflash-416.html</guid>
										<title>1997 Corvette: Product Campaign: PCM Calibration Reflash</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-product-campaign-pcm-calibration-reflash-416.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-erratic-fuel-gauge-readings-415.html</guid>
										<title>1997 Corvette: Service Bulletin: Erratic Fuel Gauge Readings</title>
