<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-heat-shielding-132.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-incorrect-camshafts-in-production-at-flint-engine-plant-1107.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Incorrect Camshafts in Production at Flint Engine Plant</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-incorrect-camshafts-in-production-at-flint-engine-plant-1107.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-leakage-at-oil-filter-1081.html</guid>
										<title>1968 Corvette Service Bulletin:  Leakage at Oil Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-leakage-at-oil-filter-1081.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-1973-corvette-service-bulletin-engine-overheat-1220.html</guid>
										<title>1970 - 1973 Corvette:  Service Bulletin:  Engine Overheat</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-1973-corvette-service-bulletin-engine-overheat-1220.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-features-sheet-chevrolet-l88-engine-assembly-features-1177.html</guid>
										<title>1968 Corvette:  Features Sheet:  Chevrolet L88 Engine Assembly Features</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-features-sheet-chevrolet-l88-engine-assembly-features-1177.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-water-entry-into-fuel-tank-1092-1125.html</guid>
										<title>1968 - 1969 Corvette:  Engineering Service Letter:  Water Entry Into Fuel Tank (#1092)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-water-entry-into-fuel-tank-1092-1125.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-news-red-idle-mixture-screw-caps-822.html</guid>
										<title>1973 Corvette: Service News: Red Idle Mixture Screw Caps</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-news-red-idle-mixture-screw-caps-822.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-rear-axle-identification-revision-1169.html</guid>
										<title>1977 Corvette:  Service Bulletin:  Rear Axle Identification Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-rear-axle-identification-revision-1169.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-679.html</guid>
										<title>1970 Corvette: Service News: 1970 Carburetor Linkage and Accelerator Controls</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-679.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-bulletin-blown-thermal-fuse-diagnosis-1127.html</guid>
										<title>1972 Corvette:  Service Bulletin:  Blown Thermal Fuse Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-bulletin-blown-thermal-fuse-diagnosis-1127.html</link>
