<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-vehicle-time-out-for-parasitic-draw-testing-1318.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-product-safety-recall-frontal-airbag-and-pretensioner-non-deploy-jul-10-2017-1376.html</guid>
										<title>2014 - 2017 Corvette: Product Safety Recall: Frontal Airbag and Pretensioner Non Deploy - (Jul 10, 2017)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-product-safety-recall-frontal-airbag-and-pretensioner-non-deploy-jul-10-2017-1376.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-incorrect-song-information-displayed-1185.html</guid>
										<title>2015 Corvette:  GM TechLink:  Incorrect Song Information Displayed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-incorrect-song-information-displayed-1185.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-intermittent-loss-of-rear-camera-gridlines-and-or-service-rear-vision-system-message-1310.html</guid>
										<title>2016 - 2017 Corvette: Service Bulletin: Intermittent Loss of Rear Camera Gridlines and/or Service Rear Vision System Message</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-intermittent-loss-of-rear-camera-gridlines-and-or-service-rear-vision-system-message-1310.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-infotainment-system-upgrade-for-android-auto-feature-1261.html</guid>
										<title>2016 Corvette: Service Bulletin:  Infotainment System Upgrade for Android Auto Feature</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-infotainment-system-upgrade-for-android-auto-feature-1261.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-repeat-dtcs-p2096-and-p2098-1385.html</guid>
										<title>2014 - 2017 Corvette:  GM TechLink:  Repeat DTCs P2096 and P2098</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-repeat-dtcs-p2096-and-p2098-1385.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-hvac-temperature-fluctuations-4.html</guid>
										<title>2014 Corvette: GM TechLink Article: HVAC Temperature Fluctuations</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-hvac-temperature-fluctuations-4.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-diagnostic-tip-for-malfunction-indicator-light-mil-illuminated-dtc-p0420-and-p0430-set-1277.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin: Diagnostic Tip for Malfunction Indicator Light (MIL) Illuminated, DTC P0420 and P0430 Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-diagnostic-tip-for-malfunction-indicator-light-mil-illuminated-dtc-p0420-and-p0430-set-1277.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-corvette-radio-control-assembly-replacement-11.html</guid>
										<title>2014 Corvette: GM TechLink Article: Corvette Radio Control Assembly Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-corvette-radio-control-assembly-replacement-11.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-pip5159b-engine-misfire-may-be-due-to-loose-spark-plug-wires-1309.html</guid>
										<title>2014 - 2015 Corvette: Service Bulletin: #PIP5159B: Engine Misfire May Be Due To loose Spark Plug Wires</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-pip5159b-engine-misfire-may-be-due-to-loose-spark-plug-wires-1309.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-corvette-driver-mode-control-2.html</guid>
										<title>2014 Corvette: GM TechLink Article: Corvette Driver Mode Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-corvette-driver-mode-control-2.html</link>
