<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-gm-techlink-3rd-gear-condition-on-manual-transmission-1317.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-16-na-014-delayed-engagement-after-sitting-with-engine-off-1290.html</guid>
										<title>2015 - 2016 Corvette: Service Bulletin: #16-NA-014: Delayed Engagement After Sitting With Engine Off</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-16-na-014-delayed-engagement-after-sitting-with-engine-off-1290.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-reprogramming-procedures-for-the-8l90-8-speed-transmission-1198.html</guid>
										<title>2015 Corvette:  GM TechLink:  Reprogramming Procedures for the 8L90 8-Speed Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-reprogramming-procedures-for-the-8l90-8-speed-transmission-1198.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-and-grand-sport-service-bulletin-pip5500-whine-growl-noise-cold-below-40*f-4*c-1369.html</guid>
										<title>2017 Corvette Z06 and Grand Sport: Service Bulletin: #PIP5500: Whine growl noise cold (below 40*F/4*C)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-and-grand-sport-service-bulletin-pip5500-whine-growl-noise-cold-below-40*f-4*c-1369.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-16-na-364-delayed-engagement-after-sitting-with-engine-off-clutch-slow-to-fill-1373.html</guid>
										<title>2015 - 2017 Corvette: Service Bulletin: #16-NA-364: Delayed Engagement After Sitting With Engine Off - Clutch Slow to Fill</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-16-na-361-information-on-transmission-harsh-1-2-shift-upon-first-start-up-shift-of-the-day-under-light-throttle-1354.html</guid>
										<title>2015 - 2019 Corvette: Service Bulletin: #16-NA-361: Information on Transmission Harsh 1-2 Shift Upon First Start Up/Shift of the Day Under Light Throttle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-16-na-361-information-on-transmission-harsh-1-2-shift-upon-first-start-up-shift-of-the-day-under-light-throttle-1354.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/c7-corvette-service-information-transmission-control-lever-knob-replacement-1294.html</guid>
										<title>C7 Corvette:  Service Information:  Transmission Control Lever Knob Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/c7-corvette-service-information-transmission-control-lever-knob-replacement-1294.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-16-na-175-shake-and-or-shudder-during-light-throttle-acceleration-between-25-and-80-mph-40-and-128-km-h-at-a-steady-state-1382.html</guid>
										<title>2015 - 2017 Corvette:  Service Bulletin: #16-NA-175: Shake and/or Shudder During Light Throttle Acceleration Between 25 and 80 MPH (40 and 128 KM/H) at a Steady State</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-16-na-175-shake-and-or-shudder-during-light-throttle-acceleration-between-25-and-80-mph-40-and-128-km-h-at-a-steady-state-1382.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-gm-techlink-diagnostic-tips-for-harsh-shifting-transmission-conditions-1380.html</guid>
										<title>2015 - 2017 Corvette: GM TechLink:  Diagnostic Tips for Harsh Shifting Transmission Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-gm-techlink-diagnostic-tips-for-harsh-shifting-transmission-conditions-1380.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-recall-low-rear-differential-fluid-level-847.html</guid>
										<title>2014 Corvette: Recall: Low Rear Differential Fluid Level</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-recall-low-rear-differential-fluid-level-847.html</link>
