<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-16009-primary-tank-inlet-check-valve-fuel-and-vapor-leaks-1312.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-gm-techlink-air-filter-box-seal-leak-1269.html</guid>
										<title>2014 - 2016 Corvette:  GM TechLink:  Air Filter Box Seal Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-gm-techlink-air-filter-box-seal-leak-1269.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-service-bulletin-pip5492-scraping-or-moan-noise-heard-during-engine-idle-1356.html</guid>
										<title>2017 Corvette Z06: Service Bulletin: #PIP5492: Scraping or Moan Noise heard During Engine Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-service-bulletin-pip5492-scraping-or-moan-noise-heard-during-engine-idle-1356.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-fuel-injector-and-oil-ring-seal-replacement-1011.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink:  Fuel Injector and Oil Ring Seal Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-fuel-injector-and-oil-ring-seal-replacement-1011.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5179d-extended-crank-cold-with-di-direct-injected-engines-mar-27-2018-1351.html</guid>
										<title>2014 - 2018 Corvette:  Service Bulletin: #PIP5179D: Extended Crank Cold With DI (Direct Injected) Engines - (Mar 27, 2018)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5179d-extended-crank-cold-with-di-direct-injected-engines-mar-27-2018-1351.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5234c-information-for-servicing-fuel-injector-oil-ring-seal-replacement-for-fuel-odor-and-or-extended-cranking-condition-1360.html</guid>
										<title>2014 - 2017 Corvette: Service Bulletin: #PIP5234C: Information For Servicing Fuel Injector Oil Ring Seal Replacement For Fuel Odor And/or Extended Cranking Condition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5234c-information-for-servicing-fuel-injector-oil-ring-seal-replacement-for-fuel-odor-and-or-extended-cranking-condition-1360.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-how-to-remove-stuck-lifters-1246.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink:  How to Remove Stuck Lifters</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-how-to-remove-stuck-lifters-1246.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin:  Code P06DD No Or Low Oil Pressure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-service-bulletin-20-na-200-diagnostic-tip-for-malfunction-indicator-lamp-mil-illuminated-dtc-p0172-and-or-p0175-set-1447.html</guid>
										<title>2016 - 2019 Corvette: Service Bulletin: #20-NA-200: Diagnostic Tip for Malfunction Indicator Lamp (MIL) Illuminated - DTC P0172 and/or P0175 Set</title>
