<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-low-oil-pressure-message-light-inspect-valve-lifter-oil-filter-1298.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-oil-leak-after-the-harmonic-balancer-is-removed-1065.html</guid>
										<title>2014 Corvette:  GM TechLink:  Oil Leak after the Harmonic Balancer is Removed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-oil-leak-after-the-harmonic-balancer-is-removed-1065.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-active-fuel-management-dynamic-fuel-management-on-gm-models-1418.html</guid>
										<title>2016 - 2019 Corvette: GM TechLink: Active Fuel Management/Dynamic Fuel Management on GM Models</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-active-fuel-management-dynamic-fuel-management-on-gm-models-1418.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-setting-the-timing-on-gen-5-v6-and-v8-engines-1405.html</guid>
										<title>2016 - 2019 Corvette: GM TechLink: Setting the Timing on Gen 5 V6 and V8 Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-setting-the-timing-on-gen-5-v6-and-v8-engines-1405.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin:  Code P06DD No Or Low Oil Pressure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</guid>
										<title>2014 - 2018 Corvette:  Service Bulletin:  #PIP5248D: Stalling Shudder And/or Hard   shifting Into 1st Gear Or Reverse Vibration On launch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-service-bulletin-20-na-200-diagnostic-tip-for-malfunction-indicator-lamp-mil-illuminated-dtc-p0172-and-or-p0175-set-1447.html</guid>
										<title>2016 - 2019 Corvette: Service Bulletin: #20-NA-200: Diagnostic Tip for Malfunction Indicator Lamp (MIL) Illuminated - DTC P0172 and/or P0175 Set</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5234c-information-for-servicing-fuel-injector-oil-ring-seal-replacement-for-fuel-odor-and-or-extended-cranking-condition-1360.html</guid>
										<title>2014 - 2017 Corvette: Service Bulletin: #PIP5234C: Information For Servicing Fuel Injector Oil Ring Seal Replacement For Fuel Odor And/or Extended Cranking Condition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5234c-information-for-servicing-fuel-injector-oil-ring-seal-replacement-for-fuel-odor-and-or-extended-cranking-condition-1360.html</link>
