										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-gasoline-engine-oil-requirements-333.html</guid>
										<title>2005 Corvette: GM TechLink: Gasoline Engine Oil Requirements</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-gasoline-engine-oil-requirements-333.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-2013-corvette-service-bulletin-pf48-pf48f-oil-filter-redesign-851.html</guid>
										<title>2008 - 2013 Corvette: Service Bulletin: PF48 / PF48F Oil Filter Redesign</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-2013-corvette-service-bulletin-pf48-pf48f-oil-filter-redesign-851.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-ls2-engine-trouble-codes-listing-332.html</guid>
										<title>2005 Corvette: LS2 Engine Trouble Codes Listing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-ls2-engine-trouble-codes-listing-332.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2017-corvette-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-1344.html</guid>
										<title>2006 - 2017 Corvette:  Service Bulletin:  #PIP4112R: Normal Characteristic - Sag Or Hesitation On Acceleration - (Mar 24, 2017)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2017-corvette-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-1344.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2010-2011-corvette-gm-techlink-engine-misfires-66.html</guid>
										<title>2010 - 2011 Corvette:  GM TechLink: Engine Misfires</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2010-2011-corvette-gm-techlink-engine-misfires-66.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-gm-techlink-article-dtc-p0300-setting-after-engine-repairs-6.html</guid>
										<title>2005 - 2013 Corvette: GM TechLink Article: DTC P0300 Setting after Engine Repairs</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-gm-techlink-article-dtc-p0300-setting-after-engine-repairs-6.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-low-coolant-system-operation-328.html</guid>
										<title>2005 Corvette: GM TechLink: Low Coolant System Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-low-coolant-system-operation-328.html</link>
