<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2013-corvette-service-bulletin-15682-primary-tank-module-flange-fuel-and-vapor-leaks-1293.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2013-corvette-service-bulletin-15682-primary-tank-module-flange-fuel-and-vapor-leaks-revised-1297.html</guid>
										<title>2007 - 2013 Corvette: Service Bulletin: 15682 Primary Tank Module Flange Fuel and Vapor Leaks - Revised</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-gasoline-engine-oil-requirements-333.html</guid>
										<title>2005 Corvette: GM TechLink: Gasoline Engine Oil Requirements</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-gasoline-engine-oil-requirements-333.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2010-2011-corvette-gm-techlink-engine-misfires-66.html</guid>
										<title>2010 - 2011 Corvette:  GM TechLink: Engine Misfires</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2010-2011-corvette-gm-techlink-engine-misfires-66.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2008-corvette-gm-techlink-article-intake-airflow-disturbance-105.html</guid>
										<title>2007 - 2008 Corvette: GM TechLink Article: Intake Airflow Disturbance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2008-corvette-gm-techlink-article-intake-airflow-disturbance-105.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2005-corvette-gm-techlink-fuel-line-quick-connectors-387.html</guid>
										<title>2004 - 2005 Corvette: GM TechLink: Fuel Line Quick Connectors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2005-corvette-gm-techlink-fuel-line-quick-connectors-387.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-gm-techlink-article-dtc-p0300-setting-after-engine-repairs-6.html</guid>
										<title>2005 - 2013 Corvette: GM TechLink Article: DTC P0300 Setting after Engine Repairs</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-gm-techlink-article-dtc-p0300-setting-after-engine-repairs-6.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-recall-power-steering-hose-fracture-334.html</guid>
										<title>2005 - 2006 Corvette: Recall: Power Steering Hose Fracture</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-recall-power-steering-hose-fracture-334.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-engine-controls-207.html</guid>
										<title>2006 Corvette: Electrical Schematic: Engine Controls</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-engine-controls-207.html</link>
