<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2004-corvette-convertible-top-operating-instructions-1292.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-general-waterleak-guide-466.html</guid>
										<title>1997 - 2004 Corvette: Service Bulletin: General Waterleak Guide</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-general-waterleak-guide-466.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-left-headlamp-door-does-not-stay-closed-455.html</guid>
										<title>2000 Corvette: Service Bulletin: Left Headlamp Door Does Not Stay Closed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-left-headlamp-door-does-not-stay-closed-455.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-tonneau-cover-makes-noise-when-going-over-bumps-462.html</guid>
										<title>1998 Corvette Convertible: Service Bulletin: Tonneau Cover Makes Noise When Going Over Bumps</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-tonneau-cover-makes-noise-when-going-over-bumps-462.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-front-fender-to-door-fit-appearance-install-retainer-473.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Front Fender to Door Fit/Appearance (Install Retainer)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-front-fender-to-door-fit-appearance-install-retainer-473.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-waterleak-above-door-glass-reseal-blowout-clip-469.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Waterleak Above Door Glass (Reseal Blowout Clip)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-waterleak-above-door-glass-reseal-blowout-clip-469.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-clicking-noise-coming-from-folding-top-463.html</guid>
										<title>1998 Corvette Convertible: Service Bulletin: Clicking Noise Coming From Folding Top</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-clicking-noise-coming-from-folding-top-463.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-technical-article-corvette-converts-floor-panels-wheelhousings-from-glass-to-chopped-carbon-366.html</guid>
										<title>1997+ Corvette: Technical Article: Corvette Converts Floor Panels, Wheelhousings From Glass To Chopped Carbon</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-technical-article-corvette-converts-floor-panels-wheelhousings-from-glass-to-chopped-carbon-366.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-hatch-will-not-pop-up-when-activated-in-cold-weather-465.html</guid>
										<title>1997 Corvette: Service Bulletin: Hatch Will Not Pop Up When Activated in Cold Weather</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-hatch-will-not-pop-up-when-activated-in-cold-weather-465.html</link>
