<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-16-na-014-delayed-engagement-after-sitting-with-engine-off-1290.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-recall-low-rear-differential-fluid-level-847.html</guid>
										<title>2014 Corvette: Recall: Low Rear Differential Fluid Level</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-recall-low-rear-differential-fluid-level-847.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-16-na-404-harsh-shift-delayed-shift-unwanted-downshift-transmission-stuck-in-one-gear-erratic-shifting-hesitation-or-have-a-malfunction-indicator-lamp-mil-illuminated-1353.html</guid>
										<title>2017 Corvette:  Service Bulletin:  #16-NA-404: Harsh Shift, Delayed Shift, unwanted Downshift, Transmission Stuck in One Gear, Erratic Shifting, Hesitation or Have a Malfunction Indicator Lamp (MIL) Illuminated</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-16-na-404-harsh-shift-delayed-shift-unwanted-downshift-transmission-stuck-in-one-gear-erratic-shifting-hesitation-or-have-a-malfunction-indicator-lamp-mil-illuminated-1353.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-16-na-361-information-on-transmission-harsh-1-2-shift-upon-first-start-up-shift-of-the-day-under-light-throttle-1354.html</guid>
										<title>2015 - 2019 Corvette: Service Bulletin: #16-NA-361: Information on Transmission Harsh 1-2 Shift Upon First Start Up/Shift of the Day Under Light Throttle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-16-na-361-information-on-transmission-harsh-1-2-shift-upon-first-start-up-shift-of-the-day-under-light-throttle-1354.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-17098-service-update-8-speed-transmission-check-engine-light-mar-23-2017-1343.html</guid>
										<title>2017 Corvette: Service Bulletin: #17098: Service Update - 8-Speed Transmission Check Engine Light - (Mar 23, 2017)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-17098-service-update-8-speed-transmission-check-engine-light-mar-23-2017-1343.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-diagnostic-tip-for-harsh-shifts-after-mileage-accumulation-without-previous-transmission-repairs-and-or-calibration-updates-1286.html</guid>
										<title>2015 - 2016 Corvette:  Service Bulletin: Diagnostic Tip for Harsh Shifts After Mileage Accumulation Without Previous Transmission Repairs and/or Calibration Updates</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-diagnostic-tip-for-harsh-shifts-after-mileage-accumulation-without-previous-transmission-repairs-and-or-calibration-updates-1286.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-recall-16038-transmission-oil-cooler-line-in-contact-with-body-stud-1322.html</guid>
										<title>2016 Corvette:  Recall:  16038 Transmission Oil Cooler Line in Contact with Body Stud</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-recall-16038-transmission-oil-cooler-line-in-contact-with-body-stud-1322.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-all-new-8l90-8-speed-automatic-transmission-1197.html</guid>
										<title>2015 Corvette:  GM TechLink:  All New 8L90 8-Speed Automatic Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-all-new-8l90-8-speed-automatic-transmission-1197.html</link>
