<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-diagnostic-tip-for-harsh-shifts-after-mileage-accumulation-without-previous-transmission-repairs-and-or-calibration-updates-1286.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-gm-techlink-3rd-gear-condition-on-manual-transmission-1317.html</guid>
										<title>2017 Corvette:  GM TechLink:  3rd Gear Condition on Manual Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-gm-techlink-3rd-gear-condition-on-manual-transmission-1317.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-techlink-article-corvette-driveline-support-alignment-22.html</guid>
										<title>2014 Corvette: Techlink Article: Corvette Driveline Support Alignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-techlink-article-corvette-driveline-support-alignment-22.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-17098-service-update-8-speed-transmission-check-engine-light-mar-23-2017-1343.html</guid>
										<title>2017 Corvette: Service Bulletin: #17098: Service Update - 8-Speed Transmission Check Engine Light - (Mar 23, 2017)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-17098-service-update-8-speed-transmission-check-engine-light-mar-23-2017-1343.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-shake-or-shudder-on-acceleration-excessive-engine-rpm-fluctuation-between-30-and-65-mph-1300.html</guid>
										<title>2015 - 2016 Corvette: Service Bulletin: Shake Or Shudder On Acceleration Excessive Engine RPM Fluctuation Between 30 And 65 MPH</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-shake-or-shudder-on-acceleration-excessive-engine-rpm-fluctuation-between-30-and-65-mph-1300.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-pip5437b-8l45-8l90-diagnostic-tips-for-harsh-shifts-and-delayed-or-harsh-garage-shift-engagements-1365.html</guid>
										<title>2015 - 2017 Corvette: Service Bulletin: #PIP5437B: 8L45 8L90 Diagnostic Tips for Harsh Shifts and Delayed or Harsh Garage Shift Engagements</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-pip5437b-8l45-8l90-diagnostic-tips-for-harsh-shifts-and-delayed-or-harsh-garage-shift-engagements-1365.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-18-na-285-information-on-slight-movement-in-park-at-ignition-on-and-vehicle-start-up-and-or-during-a-remote-vehicle-start-event-jan-22-2021-1486.html</guid>
										<title>2015 - 2019 Corvette: Service Bulletin: #18-NA-285: Information on Slight Movement in Park at Ignition On and Vehicle Start Up and/or During a Remote Vehicle Start Event - (Jan 22, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-18-na-285-information-on-slight-movement-in-park-at-ignition-on-and-vehicle-start-up-and-or-during-a-remote-vehicle-start-event-jan-22-2021-1486.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-reprogramming-procedures-for-the-8l90-8-speed-transmission-1198.html</guid>
										<title>2015 Corvette:  GM TechLink:  Reprogramming Procedures for the 8L90 8-Speed Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-reprogramming-procedures-for-the-8l90-8-speed-transmission-1198.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-all-new-8l90-8-speed-automatic-transmission-1197.html</guid>
										<title>2015 Corvette:  GM TechLink:  All New 8L90 8-Speed Automatic Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-all-new-8l90-8-speed-automatic-transmission-1197.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/c7-corvette-service-information-transmission-control-lever-knob-replacement-1294.html</guid>
										<title>C7 Corvette:  Service Information:  Transmission Control Lever Knob Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/c7-corvette-service-information-transmission-control-lever-knob-replacement-1294.html</link>
