<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-transport-mode-on-message-displayed-in-driver-information-center-dic-and-or-battery-light-is-flashing-1283.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-pic6439-diagnostic-tip-for-a-b1517-dtc-battery-negative-cable-jun-25-2021-1521.html</guid>
										<title>2014 - 2019 Corvette: Service Bulletin: #PIC6439: Diagnostic Tip for a B1517 DTC - Battery Negative Cable - (Jun 25, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-pic6439-diagnostic-tip-for-a-b1517-dtc-battery-negative-cable-jun-25-2021-1521.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-techline-infotainment-dvd-software-update-1161.html</guid>
										<title>2014 Corvette:  GM TechLink:  Techline Infotainment DVD Software Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-techline-infotainment-dvd-software-update-1161.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-service-bulletin-instrument-cluster-driver-information-center-goes-blank-or-analog-speedometer-inaccurate-1229.html</guid>
										<title>2015 Corvette:  Service Bulletin:  Instrument Cluster Driver Information Center Goes Blank or Analog Speedometer Inaccurate</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-service-bulletin-instrument-cluster-driver-information-center-goes-blank-or-analog-speedometer-inaccurate-1229.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-compass-always-shows-north-1259.html</guid>
										<title>2014 Corvette:  GM TechLink:  Compass Always Shows North</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-compass-always-shows-north-1259.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-power-memory-seat-operation-3.html</guid>
										<title>2014 Corvette: GM TechLink Article: Power Memory Seat Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-power-memory-seat-operation-3.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-hvac-temperature-fluctuations-4.html</guid>
										<title>2014 Corvette: GM TechLink Article: HVAC Temperature Fluctuations</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-hvac-temperature-fluctuations-4.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-corvette-driver-mode-control-2.html</guid>
										<title>2014 Corvette: GM TechLink Article: Corvette Driver Mode Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-corvette-driver-mode-control-2.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-repeat-dtcs-p2096-and-p2098-1385.html</guid>
										<title>2014 - 2017 Corvette:  GM TechLink:  Repeat DTCs P2096 and P2098</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-repeat-dtcs-p2096-and-p2098-1385.html</link>
