<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-recalibration-of-carter-afb-carburetors-128.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-water-pump-pulley-failures-84.html</guid>
										<title>1966 Corvette: Service Bulletin: Water Pump Pulley Failures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-water-pump-pulley-failures-84.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-news-radiator-service-updates-734.html</guid>
										<title>1963 Corvette: Service News: Radiator Service Updates</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-news-radiator-service-updates-734.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1965-corvette-service-bulletin-drive-line-noise-1084.html</guid>
										<title>1963 - 1965 Corvette:  Service Bulletin:  Drive Line Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1965-corvette-service-bulletin-drive-line-noise-1084.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-knowing-how-your-1963-1982-corvette-s-cooling-system-can-prevent-a-steaming-summer-241.html</guid>
										<title>1963 - 1982 Corvette: Technical Article: Knowing How Your 1963 - 1982 Corvette`s Cooling System Can Prevent a Steaming Summer</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-knowing-how-your-1963-1982-corvette-s-cooling-system-can-prevent-a-steaming-summer-241.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-valve-spring-cap-failure-425-h-p-396-ci-engines-731.html</guid>
										<title>1965 Corvette: Service Bulletin: Valve Spring Cap Failure - 425 H.P., 396 ci. Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-valve-spring-cap-failure-425-h-p-396-ci-engines-731.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1970-corvette-service-news-heavy-duty-positraction-unit-1207.html</guid>
										<title>1963 - 1970 Corvette:  Service News:  Heavy Duty Positraction Unit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1970-corvette-service-news-heavy-duty-positraction-unit-1207.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-corvette-427-mark-iv-engine-surge-no-358-t-i-1017.html</guid>
										<title>1966 Corvette:  Engineering Service Letter:  Corvette 427 Mark IV Engine Surge (No. 358-T.I.)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-corvette-427-mark-iv-engine-surge-no-358-t-i-1017.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-dying-on-quick-right-turns-732.html</guid>
										<title>1965 Corvette: Engineering Service Letter: Dying on Quick Right Turns</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-dying-on-quick-right-turns-732.html</link>
