										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-16-na-014-delayed-engagement-after-sitting-with-engine-off-1290.html</guid>
										<title>2015 - 2016 Corvette: Service Bulletin: #16-NA-014: Delayed Engagement After Sitting With Engine Off</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-16-na-014-delayed-engagement-after-sitting-with-engine-off-1290.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-diagnostic-tip-for-harsh-shifts-after-mileage-accumulation-without-previous-transmission-repairs-and-or-calibration-updates-1286.html</guid>
										<title>2015 - 2016 Corvette:  Service Bulletin: Diagnostic Tip for Harsh Shifts After Mileage Accumulation Without Previous Transmission Repairs and/or Calibration Updates</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-diagnostic-tip-for-harsh-shifts-after-mileage-accumulation-without-previous-transmission-repairs-and-or-calibration-updates-1286.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-16-na-361-information-on-transmission-harsh-1-2-shift-upon-first-start-up-shift-of-the-day-under-light-throttle-1354.html</guid>
										<title>2015 - 2019 Corvette: Service Bulletin: #16-NA-361: Information on Transmission Harsh 1-2 Shift Upon First Start Up/Shift of the Day Under Light Throttle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-16-na-361-information-on-transmission-harsh-1-2-shift-upon-first-start-up-shift-of-the-day-under-light-throttle-1354.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-16-na-364-delayed-engagement-after-sitting-with-engine-off-clutch-slow-to-fill-1373.html</guid>
										<title>2015 - 2017 Corvette: Service Bulletin: #16-NA-364: Delayed Engagement After Sitting With Engine Off - Clutch Slow to Fill</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-recall-16038-transmission-oil-cooler-line-in-contact-with-body-stud-1322.html</guid>
										<title>2016 Corvette:  Recall:  16038 Transmission Oil Cooler Line in Contact with Body Stud</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-recall-16038-transmission-oil-cooler-line-in-contact-with-body-stud-1322.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-pip5784-8l45-8l90-automatic-transmissions-with-no-movement-after-valve-body-replacement-mar-1-2021-1493.html</guid>
										<title>2015 - 2019 Corvette: Service Bulletin: #PIP5784: 8L45 8L90 Automatic Transmissions With No Movement After Valve Body Replacement - (Mar 1, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-pip5784-8l45-8l90-automatic-transmissions-with-no-movement-after-valve-body-replacement-mar-1-2021-1493.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-shift-concerns-on-8-speed-transmissions-1531.html</guid>
										<title>2015 - 2018 Corvette: Shift Concerns on 8-Speed Transmissions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-shift-concerns-on-8-speed-transmissions-1531.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-17098-service-update-8-speed-transmission-check-engine-light-mar-23-2017-1343.html</guid>
										<title>2017 Corvette: Service Bulletin: #17098: Service Update - 8-Speed Transmission Check Engine Light - (Mar 23, 2017)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-17098-service-update-8-speed-transmission-check-engine-light-mar-23-2017-1343.html</link>
