<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-surge-misfire-feeling-sensation-during-highway-steady-state-driving-jun-6-2016-1272.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-rough-idle-or-vibration-989.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink:  Rough Idle or Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-rough-idle-or-vibration-989.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-2024-corvette-crankshaft-bearing-diagnosis-1529.html</guid>
										<title>2019 - 2024 Corvette: Crankshaft Bearing Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-2024-corvette-crankshaft-bearing-diagnosis-1529.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-z06-gm-techlink-hard-shifting-into-1st-gear-or-reverse-1379.html</guid>
										<title>2015 - 2018 Corvette Z06:  GM TechLink:  Hard Shifting into 1st Gear or Reverse</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-z06-gm-techlink-hard-shifting-into-1st-gear-or-reverse-1379.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2012-2017-corvette-service-bulletin-17-na-157-information-on-spin-on-oil-filter-replacement-for-gas-engines-designed-with-new-oil-pump-control-systems-1363.html</guid>
										<title>2012 - 2017 Corvette: Service Bulletin: #17-NA-157: Information on Spin-On Oil Filter Replacement for Gas Engines Designed with New Oil Pump Control Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2012-2017-corvette-service-bulletin-17-na-157-information-on-spin-on-oil-filter-replacement-for-gas-engines-designed-with-new-oil-pump-control-systems-1363.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-break-in-oil-change-for-corvette-included-in-chevrolet-complete-care-program-1122.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink:  Break-In Oil Change for Corvette Included in Chevrolet Complete Care Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-break-in-oil-change-for-corvette-included-in-chevrolet-complete-care-program-1122.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-15-na-002-information-on-fuel-odor-and-or-fuel-leaks-from-underhood-sidi-pipes-between-high-pressure-pump-and-fuel-rails-1375.html</guid>
										<title>2015 - 2017 Corvette:  Service Bulletin: #15-NA-002: Information on Fuel Odor and/or Fuel Leaks from Underhood SIDI Pipes Between High Pressure Pump and Fuel Rails</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-15-na-002-information-on-fuel-odor-and-or-fuel-leaks-from-underhood-sidi-pipes-between-high-pressure-pump-and-fuel-rails-1375.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-17469-fuel-leaks-at-the-primary-fuel-pump-module-flange-1399.html</guid>
										<title>2014 - 2017 Corvette:  Service Bulletin: 17469 Fuel Leaks at the Primary Fuel Pump Module Flange</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-17469-fuel-leaks-at-the-primary-fuel-pump-module-flange-1399.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-active-fuel-management-dynamic-fuel-management-on-gm-models-1418.html</guid>
										<title>2016 - 2019 Corvette: GM TechLink: Active Fuel Management/Dynamic Fuel Management on GM Models</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-active-fuel-management-dynamic-fuel-management-on-gm-models-1418.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-low-oil-pressure-message-light-inspect-valve-lifter-oil-filter-1298.html</guid>
										<title>2014 - 2016 Corvette: Service Bulletin: Low Oil Pressure Message/Light - Inspect Valve Lifter Oil Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-low-oil-pressure-message-light-inspect-valve-lifter-oil-filter-1298.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-16009-primary-tank-inlet-check-valve-fuel-and-vapor-leaks-1312.html</guid>
										<title>2014 - 2015 Corvette:  Service Bulletin:  16009 Primary Tank Inlet Check Valve Fuel and Vapor Leaks</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-16009-primary-tank-inlet-check-valve-fuel-and-vapor-leaks-1312.html</link>
