<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-service-bulletin-special-coverage-adjustment-airbag-light-on-1264.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-door-locks-213.html</guid>
										<title>2006 Corvette: Electrical Schematic: Door Locks</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-door-locks-213.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-actual-outside-temperature-does-not-match-temperature-reading-on-inter-display-normal-operating-characteristic-341.html</guid>
										<title>2005 Corvette: Service Bulletin: Actual Outside Temperature Does Not Match Temperature Reading On Inter Display - Normal Operating Characteristic</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-actual-outside-temperature-does-not-match-temperature-reading-on-inter-display-normal-operating-characteristic-341.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-satellite-radio-circuit-system-266.html</guid>
										<title>2006 Corvette: Electrical Schematic: Satellite Radio Circuit System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-satellite-radio-circuit-system-266.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-front-park-turn-signal-bulb-intermittently-inoperative-205.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Front Park/Turn Signal Bulb Intermittently Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-front-park-turn-signal-bulb-intermittently-inoperative-205.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-power-distribution-260.html</guid>
										<title>2006 Corvette:  Electrical Schematic:  Power Distribution</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-power-distribution-260.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-dead-battery-reprogram-rcdlr-233.html</guid>
										<title>2007 Corvette:  Service Bulletin: Dead Battery, Reprogram RCDLR</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-dead-battery-reprogram-rcdlr-233.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-diagnostic-trouble-codes-220.html</guid>
										<title>2006 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-diagnostic-trouble-codes-220.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-diagnostic-trouble-codes-221.html</guid>
										<title>2005 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-diagnostic-trouble-codes-221.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-customer-satisfaction-program-keyless-access-system-inoperative-168.html</guid>
										<title>2008 Corvette: Customer Satisfaction Program: Keyless Access System Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-customer-satisfaction-program-keyless-access-system-inoperative-168.html</link>
