										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2018-2019-corvette-gm-techlink-intermittent-parasitic-battery-draw-below-40°-f-4°-c-1423.html</guid>
										<title>2018 - 2019 Corvette: GM TechLink: Intermittent Parasitic Battery Draw Below 40° F/4° C</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2018-2019-corvette-gm-techlink-intermittent-parasitic-battery-draw-below-40°-f-4°-c-1423.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-service-bulletin-13417-service-update-for-inventory-and-customer-vehicles-engine-protection-mode-activated-during-aggressive-driving-848.html</guid>
										<title>2014 Corvette: Service Bulletin: 13417 - Service Update for Inventory and Customer Vehicles - Engine Protection Mode Activated During Aggressive Driving</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-service-bulletin-13417-service-update-for-inventory-and-customer-vehicles-engine-protection-mode-activated-during-aggressive-driving-848.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-corvette-driver-mode-control-2.html</guid>
										<title>2014 Corvette: GM TechLink Article: Corvette Driver Mode Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-corvette-driver-mode-control-2.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-pi1116a-door-rattle-noise-from-outside-of-vehicle-during-high-radio-volume-or-high-bass-levels-sep-14-2016-1305.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin:  #PI1116A: Door Rattle Noise from Outside of Vehicle During High Radio Volume or High Bass Levels - (Sep 14, 2016)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-pi1116a-door-rattle-noise-from-outside-of-vehicle-during-high-radio-volume-or-high-bass-levels-sep-14-2016-1305.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-intermittent-loss-of-rear-camera-gridlines-and-or-service-rear-vision-system-message-1310.html</guid>
										<title>2016 - 2017 Corvette: Service Bulletin: Intermittent Loss of Rear Camera Gridlines and/or Service Rear Vision System Message</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-intermittent-loss-of-rear-camera-gridlines-and-or-service-rear-vision-system-message-1310.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-vehicle-time-out-for-parasitic-draw-testing-1318.html</guid>
										<title>2017 Corvette: Service Bulletin: Vehicle Time Out for Parasitic Draw Testing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-vehicle-time-out-for-parasitic-draw-testing-1318.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-pip5159b-engine-misfire-may-be-due-to-loose-spark-plug-wires-1309.html</guid>
										<title>2014 - 2015 Corvette: Service Bulletin: #PIP5159B: Engine Misfire May Be Due To loose Spark Plug Wires</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-pip5159b-engine-misfire-may-be-due-to-loose-spark-plug-wires-1309.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-pic6439-diagnostic-tip-for-a-b1517-dtc-battery-negative-cable-jun-25-2021-1521.html</guid>
										<title>2014 - 2019 Corvette: Service Bulletin: #PIC6439: Diagnostic Tip for a B1517 DTC - Battery Negative Cable - (Jun 25, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-pic6439-diagnostic-tip-for-a-b1517-dtc-battery-negative-cable-jun-25-2021-1521.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-heated-seat-may-turn-off-1.html</guid>
										<title>2014 Corvette: GM TechLink Article: Heated Seat May Turn Off</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-heated-seat-may-turn-off-1.html</link>
