<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-compass-always-shows-north-1259.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-intermittent-loss-of-rear-camera-gridlines-and-or-service-rear-vision-system-message-1310.html</guid>
										<title>2016 - 2017 Corvette: Service Bulletin: Intermittent Loss of Rear Camera Gridlines and/or Service Rear Vision System Message</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-intermittent-loss-of-rear-camera-gridlines-and-or-service-rear-vision-system-message-1310.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-heated-and-ventilated-front-seats-inoperative-with-remote-start-1265.html</guid>
										<title>2016 Corvette: Service Bulletin:  Heated and Ventilated Front Seats Inoperative with Remote Start</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-heated-and-ventilated-front-seats-inoperative-with-remote-start-1265.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2019-corvette-gm-techlink-power-folding-top-diagnostic-tips-1410.html</guid>
										<title>2005 - 2019 Corvette: GM TechLink: Power Folding Top Diagnostic Tips</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2019-corvette-gm-techlink-power-folding-top-diagnostic-tips-1410.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2016-corvette-15521-customer-advisory-letter-side-door-release-operation-phase-2-mailing-1268.html</guid>
										<title>2005 - 2016 Corvette: 15521 - Customer Advisory Letter - Side Door Release Operation - Phase 2 Mailing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2016-corvette-15521-customer-advisory-letter-side-door-release-operation-phase-2-mailing-1268.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-16-na-188-loss-of-radio-controls-and-or-hvac-controls-jun-13-2016-1278.html</guid>
										<title>2014 - 2016 Corvette: Service Bulletin: #16-NA-188: Loss of Radio Controls and/or HVAC Controls - (Jun 13, 2016)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-16-na-188-loss-of-radio-controls-and-or-hvac-controls-jun-13-2016-1278.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2018-2019-corvette-gm-techlink-intermittent-parasitic-battery-draw-below-40°-f-4°-c-1423.html</guid>
										<title>2018 - 2019 Corvette: GM TechLink: Intermittent Parasitic Battery Draw Below 40° F/4° C</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2018-2019-corvette-gm-techlink-intermittent-parasitic-battery-draw-below-40°-f-4°-c-1423.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-16-na-219-gps-inoperative-red-line-across-gps-indicator-or-the-location-is-stuck-in-warren-michigan-1289.html</guid>
										<title>2016 Corvette:  Service Bulletin:  #16-NA-219: GPS Inoperative, Red Line Across GPS Indicator, or the Location is Stuck in Warren Michigan</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-16-na-219-gps-inoperative-red-line-across-gps-indicator-or-the-location-is-stuck-in-warren-michigan-1289.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-corvette-driver-mode-control-2.html</guid>
										<title>2014 Corvette: GM TechLink Article: Corvette Driver Mode Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-corvette-driver-mode-control-2.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5467a-repeat-codes-p2096-and-p2098-1383.html</guid>
										<title>2014 - 2017 Corvette: Service Bulletin: #PIP5467A: Repeat Codes P2096 and P2098</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5467a-repeat-codes-p2096-and-p2098-1383.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-navigation-radio-destination-state-defaults-to-wv-instead-of-va-on-manual-entry-only-1307.html</guid>
										<title>2016 Corvette:  Service Bulletin: Navigation Radio Destination State Defaults To WV Instead of VA On Manual Entry Only</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-navigation-radio-destination-state-defaults-to-wv-instead-of-va-on-manual-entry-only-1307.html</link>
