<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-advance-information-inter-organization-letter-anti-theft-audio-alarm-1256.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-high-energy-ignition-system-service-update-1079.html</guid>
										<title>1975 Corvette:  Service News:  High Energy Ignition System - Service Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-high-energy-ignition-system-service-update-1079.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-checking-connector-terminal-contact-metri-pack-691.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Checking Connector Terminal Contact - Metri-Pack</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-checking-connector-terminal-contact-metri-pack-691.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-spark-plug-removal-with-427-engine-and-a-c-680.html</guid>
										<title>1968 Corvette: Service News: Spark Plug Removal with 427 Engine and A/C</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-spark-plug-removal-with-427-engine-and-a-c-680.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-bulletin-moisture-entering-pulse-amplifier-transistor-ignition-systems-932.html</guid>
										<title>1965 - 1972 Corvette:  Service Bulletin:  Moisture Entering Pulse Amplifier - Transistor Ignition Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-bulletin-moisture-entering-pulse-amplifier-transistor-ignition-systems-932.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-directional-signal-switch-removal-and-installation-1136.html</guid>
										<title>1969 Corvette:  Service News:  Directional Signal Switch Removal and Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-directional-signal-switch-removal-and-installation-1136.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-heat-shield-starting-motor-solenoid-907.html</guid>
										<title>1968 - 1969 Corvette:  Engineering Service Letter:  Heat Shield - Starting Motor Solenoid</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-heat-shield-starting-motor-solenoid-907.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematics-193.html</guid>
										<title>1973 Corvette: Electrical Schematics</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematics-193.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-1968-corvette-327-cu-in-engine-distributor-alignment-1092.html</guid>
										<title>1968 Corvette:  Service News:  1968 Corvette 327 Cu. In. Engine Distributor Alignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-1968-corvette-327-cu-in-engine-distributor-alignment-1092.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-bulletin-blown-thermal-fuse-diagnosis-1127.html</guid>
										<title>1972 Corvette:  Service Bulletin:  Blown Thermal Fuse Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-bulletin-blown-thermal-fuse-diagnosis-1127.html</link>
