<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-air-ventilator-control-cables-1250.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-chevrolet-engineering-service-letter-telescoping-steering-wheel-horn-button-cap-liner-no-42-909.html</guid>
										<title>1965 Corvette: Chevrolet Engineering Service Letter:  Telescoping Steering Wheel Horn button Cap Liner - (No. 42)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-chevrolet-engineering-service-letter-telescoping-steering-wheel-horn-button-cap-liner-no-42-909.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-4-speed-shift-lever-revision-1175.html</guid>
										<title>1964 Corvette:  Service Bulletin:  4-Speed Shift Lever Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-4-speed-shift-lever-revision-1175.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-difficult-ash-tray-removal-727.html</guid>
										<title>1963 Corvette: Service Bulletin: Difficult Ash Tray Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-difficult-ash-tray-removal-727.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-turn-signal-switch-failure-to-cancel-1209.html</guid>
										<title>1965 Corvette:  Service Bulletin:  Turn Signal Switch - Failure to Cancel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-turn-signal-switch-failure-to-cancel-1209.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-production-information-genuine-leather-seats-1148.html</guid>
										<title>1964 Corvette:  Production Information:  Genuine Leather Seats</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-production-information-genuine-leather-seats-1148.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-technical-article-steering-wheel-differences-247.html</guid>
										<title>1963 - 1967 Corvette: Technical Article:  Steering Wheel Differences</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-technical-article-steering-wheel-differences-247.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-engineering-service-letter-note-steering-shaft-upper-retaining-ring-removal-on-telescoping-columns-1106.html</guid>
										<title>1967 Corvette:  Engineering Service Letter Note:  Steering Shaft Upper Retaining Ring Removal on Telescoping Columns</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-engineering-service-letter-note-steering-shaft-upper-retaining-ring-removal-on-telescoping-columns-1106.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-transmission-shift-lever-vibration-959.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Transmission Shift Lever Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-transmission-shift-lever-vibration-959.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1966-corvette-service-bulletin-reverse-lockout-mechanism-revised-1195.html</guid>
										<title>1964 - 1966 Corvette:  Service Bulletin:  Reverse Lockout Mechanism Revised</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1966-corvette-service-bulletin-reverse-lockout-mechanism-revised-1195.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-technical-article-restoring-your-dash-cluster-244.html</guid>
										<title>1963 - 1967 Corvette: Technical Article:  Restoring Your Dash Cluster</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-technical-article-restoring-your-dash-cluster-244.html</link>
