<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-chevrolet-inter-organization-letters-1962-corvette-power-teams-125.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1963-corvette-service-news-new-fuel-injection-service-kits-available-927.html</guid>
										<title>1957 - 1963 Corvette:  Service News:  New Fuel Injection Service Kits Available</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1963-corvette-service-news-new-fuel-injection-service-kits-available-927.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</guid>
										<title>1955 Corvette:  Service Bulletin:  New Gasoline Gauge</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-corvette-aluminum-radiator-replacement-1236.html</guid>
										<title>1960 - 1961 Corvette:  Service Bulletin:  Corvette Aluminum Radiator Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-corvette-aluminum-radiator-replacement-1236.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-chevrolet-technical-test-report-fuel-economy-fuel-injection-vs-carburetion-1183.html</guid>
										<title>1957 Corvette:  Chevrolet Technical Test Report:  Fuel Economy - Fuel Injection vs. Carburetion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-chevrolet-technical-test-report-fuel-economy-fuel-injection-vs-carburetion-1183.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-service-bulletin-calibration-revised-to-correct-lean-condition-at-wide-open-throttle-955.html</guid>
										<title>1959 - 1960 Corvette:  Service Bulletin:  Calibration Revised to Correct Lean Condition at Wide Open Throttle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-service-bulletin-calibration-revised-to-correct-lean-condition-at-wide-open-throttle-955.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-technical-information-carter-afb-carburetor-revisions-163.html</guid>
										<title>1962 Corvette: Technical Information: Carter AFB Carburetor Revisions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-technical-information-carter-afb-carburetor-revisions-163.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-chevrolet-product-engineering-technical-information-spark-plug-electrode-interference-with-piston-1066.html</guid>
										<title>1961 Corvette:  Chevrolet Product Engineering Technical Information:  Spark Plug Electrode Interference With Piston</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-chevrolet-product-engineering-technical-information-spark-plug-electrode-interference-with-piston-1066.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-identification-1954-camshafts-distributor-gears-camshaft-gears-all-valve-lifters-979.html</guid>
										<title>1953 - 1954 Corvette:  Service Bulletin:  Identification - 1954 Camshafts - Distributor Gears - Camshaft Gears - All Valve Lifters</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-identification-1954-camshafts-distributor-gears-camshaft-gears-all-valve-lifters-979.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-radiator-core-usage-1157.html</guid>
										<title>1959 Corvette:  Service Bulletin:  Radiator Core Usage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-radiator-core-usage-1157.html</link>
