<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1961-corvettes-chevrolet-central-office-letter-1961-corvette-hardtops-to-fit-prior-years-1245.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-new-weatherstrip-seals-976.html</guid>
										<title>1956 Corvette:  Service Bulletin:  New Weatherstrip Seals</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-new-weatherstrip-seals-976.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-service-bulletin-front-and-rear-door-glass-loose-in-run-channels-1158.html</guid>
										<title>1959 - 1960 Corvette:  Service Bulletin:  Front and Rear Door Glass Loose in Run Channels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-service-bulletin-front-and-rear-door-glass-loose-in-run-channels-1158.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-grille-vibration-890.html</guid>
										<title>1961 Corvette:  Service Bulletin:  Corvette Grille Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-grille-vibration-890.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-windshield-washers-1173.html</guid>
										<title>1959 Corvette:  Service Bulletin:  Windshield Washers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-windshield-washers-1173.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-fuel-spillage-gas-tank-filler-cap-96.html</guid>
										<title>1961 Corvette: Service Bulletin: Corvette Fuel Spillage - Gas Tank Filler Cap</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-fuel-spillage-gas-tank-filler-cap-96.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-1961-convertible-top-adjustments-41.html</guid>
										<title>1961 Corvette:  Service Bulletin: 1961 Convertible Top Adjustments</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-1961-convertible-top-adjustments-41.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-water-leaks-corvette-doors-236.html</guid>
										<title>1953 - 1954 Corvette: Service Bulletin: Water Leaks - Corvette Doors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-water-leaks-corvette-doors-236.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-effect-of-solvents-on-lucite-acrylic-lacquer-finish-793.html</guid>
										<title>1957 Corvette: Service Bulletin: Effect of Solvents on Lucite Acrylic Lacquer Finish</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-effect-of-solvents-on-lucite-acrylic-lacquer-finish-793.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-fitting-hard-top-on-corvettes-1145.html</guid>
										<title>1957 Corvette:  Service Bulletin:  Fitting Hard Top on Corvettes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-fitting-hard-top-on-corvettes-1145.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-door-inner-panel-water-deflector-1119.html</guid>
										<title>1957 Corvette:  Service News:  Door Inner Panel Water Deflector</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-door-inner-panel-water-deflector-1119.html</link>
