<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1979-corvette-service-bulletin-power-antenna-operation-124.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-convertible-engineering-service-letter-rear-courtesy-light-shorting-out-1006.html</guid>
										<title>1968 Corvette Convertible:  Engineering Service Letter:  Rear Courtesy Light Shorting Out</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-convertible-engineering-service-letter-rear-courtesy-light-shorting-out-1006.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-ecm-codes-693.html</guid>
										<title>1981 Corvette: ECM Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-ecm-codes-693.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-parasitic-drain-on-battery-ammeter-connecting-procedure-689.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Parasitic Drain on Battery Ammeter Connecting Procedure</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-choke-problems-973.html</guid>
										<title>1969 Corvette:  Service Bulletin:  Choke Problems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-choke-problems-973.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1982-corvette-service-bulletin-care-and-maintenance-of-tape-players-and-cartridges-1116.html</guid>
										<title>1977 - 1982 Corvette:  Service Bulletin:  Care and Maintenance of Tape Players and Cartridges</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1982-corvette-service-bulletin-care-and-maintenance-of-tape-players-and-cartridges-1116.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-headlamp-opening-interference-696.html</guid>
										<title>1969 Corvette: Service Bulletin: Headlamp Opening Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-headlamp-opening-interference-696.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1980-corvette-service-news-speedometer-system-noise-diagnosis-and-repair-1188.html</guid>
										<title>1978 - 1980 Corvette:  Service News:  Speedometer System Noise Diagnosis and Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1980-corvette-service-news-speedometer-system-noise-diagnosis-and-repair-1188.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1977-corvette-service-bulletin-use-of-1976-model-ignition-key-sets-in-1977-chevrolet-passenger-vehicles-1251.html</guid>
										<title>1976 - 1977 Corvette:  Service Bulletin:  Use of 1976 Model Ignition Key Sets in 1977 Chevrolet Passenger Vehicles</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1977-corvette-service-bulletin-use-of-1976-model-ignition-key-sets-in-1977-chevrolet-passenger-vehicles-1251.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1970-corvette-service-bulletin-depressed-park-windshield-wipers-unable-to-park-915.html</guid>
										<title>1968 - 1970 Corvette:  Service Bulletin:  Depressed Park Windshield Wipers Unable to Park</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1970-corvette-service-bulletin-depressed-park-windshield-wipers-unable-to-park-915.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-937.html</guid>
										<title>1982 Corvette: Service News: Fuel injection Diagnosis Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-937.html</link>
