										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-level-gauge-dipsticks-987.html</guid>
										<title>1955 Corvette:  Service Bulletin:  Oil Level Gauge Dipsticks</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-level-gauge-dipsticks-987.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-chevrolet-product-engineering-technical-information-spark-plug-electrode-interference-with-piston-1066.html</guid>
										<title>1961 Corvette:  Chevrolet Product Engineering Technical Information:  Spark Plug Electrode Interference With Piston</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-chevrolet-product-engineering-technical-information-spark-plug-electrode-interference-with-piston-1066.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-fuel-spillage-gas-tank-filler-cap-96.html</guid>
										<title>1961 Corvette: Service Bulletin: Corvette Fuel Spillage - Gas Tank Filler Cap</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-fuel-spillage-gas-tank-filler-cap-96.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-technical-article-adjusting-the-fast-idle-speed-239.html</guid>
										<title>1966 Corvette: Technical Article:  Adjusting the Fast-Idle Speed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-technical-article-adjusting-the-fast-idle-speed-239.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-connecting-rod-bearing-part-numbers-776.html</guid>
										<title>1953 - 1959 Corvette: Connecting Rod Bearing Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-connecting-rod-bearing-part-numbers-776.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-poor-engine-performance-catalytic-converter-repair-682.html</guid>
										<title>1981 Corvette: Service Bulletin: Poor Engine Performance, Catalytic Converter Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-poor-engine-performance-catalytic-converter-repair-682.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-valve-spring-cap-failure-425-h-p-396-ci-engines-731.html</guid>
										<title>1965 Corvette: Service Bulletin: Valve Spring Cap Failure - 425 H.P., 396 ci. Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-valve-spring-cap-failure-425-h-p-396-ci-engines-731.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</guid>
										<title>1973 Corvette:  Electrical Schematic: Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</link>
