<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-passenger-car-product-bulletin-new-corvette-anti-theft-warning-system-1235.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-spark-plug-fouling-driveability-improvements-674.html</guid>
										<title>1982 Corvette: Service Bulletin: Spark Plug Fouling/Driveability Improvements</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-spark-plug-fouling-driveability-improvements-674.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-engine-harness-replacement-corvette-transistor-ignition-914.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Engine Harness Replacement Corvette Transistor Ignition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-engine-harness-replacement-corvette-transistor-ignition-914.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-1968-corvette-327-cu-in-engine-distributor-alignment-1092.html</guid>
										<title>1968 Corvette:  Service News:  1968 Corvette 327 Cu. In. Engine Distributor Alignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-1968-corvette-327-cu-in-engine-distributor-alignment-1092.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1982-corvette-service-bulletin-care-and-maintenance-of-tape-players-and-cartridges-1116.html</guid>
										<title>1977 - 1982 Corvette:  Service Bulletin:  Care and Maintenance of Tape Players and Cartridges</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1982-corvette-service-bulletin-care-and-maintenance-of-tape-players-and-cartridges-1116.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-choke-problems-973.html</guid>
										<title>1969 Corvette:  Service Bulletin:  Choke Problems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-choke-problems-973.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-glow-around-wiper-switch-rework-wiper-switch-bezel-692.html</guid>
										<title>1981 Corvette: Service Bulletin: Glow Around Wiper Switch Rework Wiper Switch Bezel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-glow-around-wiper-switch-rework-wiper-switch-bezel-692.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-at-starter-solenoid-1027.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Heat Damage to Engine Wiring Harness at Starter Solenoid</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-at-starter-solenoid-1027.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1982-corvette-parking-brake-alarm-components-and-part-numbers-1187.html</guid>
										<title>1953 - 1982 Corvette:  Parking Brake Alarm Components and Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1982-corvette-parking-brake-alarm-components-and-part-numbers-1187.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-943.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Heat Damage to Engine Wiring Harness</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-943.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-news-corvette-auxiliary-cooling-fan-wiring-revision-897.html</guid>
										<title>1979 Corvette:  Service News:  Corvette Auxiliary Cooling Fan Wiring Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-news-corvette-auxiliary-cooling-fan-wiring-revision-897.html</link>
