<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-increased-capacity-fuel-pump-1234.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-engine-bucking-and-faltering-1003.html</guid>
										<title>1965 Corvette:  Engineering Service Letter:  Engine Bucking and Faltering</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-engine-bucking-and-faltering-1003.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-dying-on-quick-right-turns-732.html</guid>
										<title>1965 Corvette: Engineering Service Letter: Dying on Quick Right Turns</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-dying-on-quick-right-turns-732.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-automatic-choke-malfunction-1059.html</guid>
										<title>1966 Corvette:  Service Bulletin:  Automatic Choke Malfunction</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-automatic-choke-malfunction-1059.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-1965-corvette-396-425-h-p-rpo-l-78-incorrect-build-28.html</guid>
										<title>1965 Corvette: Engineering Service Letter: 1965 Corvette 396-425 H.P. RPO L-78 Incorrect Build</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-1965-corvette-396-425-h-p-rpo-l-78-incorrect-build-28.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-technical-information-holley-carburetor-changes-on-396-cu-in-engines-425-h-p-1010.html</guid>
										<title>1965 Corvette: Engineering Technical Information:  Holley Carburetor Changes on 396 CU. IN. Engines - 425 H.P.</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-technical-information-holley-carburetor-changes-on-396-cu-in-engines-425-h-p-1010.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1970-corvette-service-news-heavy-duty-positraction-unit-1207.html</guid>
										<title>1963 - 1970 Corvette:  Service News:  Heavy Duty Positraction Unit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1970-corvette-service-news-heavy-duty-positraction-unit-1207.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-servicing-1964-corvette-fuel-injection-units-47.html</guid>
										<title>1964 Corvette: Service News: Servicing 1964 Corvette Fuel Injection Units</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-servicing-1964-corvette-fuel-injection-units-47.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-water-pump-pulley-failures-84.html</guid>
										<title>1966 Corvette: Service Bulletin: Water Pump Pulley Failures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-water-pump-pulley-failures-84.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1967-corvette-tonawanda-engine-service-notes-valve-springs-rocker-arms-camshafts-1224.html</guid>
										<title>1965 - 1967 Corvette:  Tonawanda Engine Service Notes:  Valve Springs, Rocker Arms, Camshafts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1967-corvette-tonawanda-engine-service-notes-valve-springs-rocker-arms-camshafts-1224.html</link>
