<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-exploded-views-of-1982-cross-fire-injection-unit-with-part-numbers-1221.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-water-entry-into-fuel-tank-1092-1125.html</guid>
										<title>1968 - 1969 Corvette:  Engineering Service Letter:  Water Entry Into Fuel Tank (#1092)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-water-entry-into-fuel-tank-1092-1125.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1969-corvette-tech-article-building-427-engines-corvette-news-1274.html</guid>
										<title>1966 - 1969 Corvette: Tech Article:  Building 427 Engines - Corvette News</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1969-corvette-tech-article-building-427-engines-corvette-news-1274.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-679.html</guid>
										<title>1970 Corvette: Service News: 1970 Carburetor Linkage and Accelerator Controls</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-679.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-bulletin-soft-push-rod-guides-837.html</guid>
										<title>1974 Corvette: Service Bulletin: Soft Push Rod Guides</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-bulletin-soft-push-rod-guides-837.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-incorrect-camshafts-in-production-at-flint-engine-plant-1107.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Incorrect Camshafts in Production at Flint Engine Plant</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-incorrect-camshafts-in-production-at-flint-engine-plant-1107.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-bulletin-water-pump-bearing-and-or-shaft-failures-1020.html</guid>
										<title>1970 Corvette:  Service Bulletin:  Water Pump Bearing and/or Shaft Failures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-bulletin-water-pump-bearing-and-or-shaft-failures-1020.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-power-steering-bracket-183.html</guid>
										<title>1968 Corvette: Service Bulletin:  Power Steering Bracket</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-power-steering-bracket-183.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-1982-corvette-service-bulletin-viton-accelerator-pumps-current-and-past-models-equipped-with-dual-and-quadrajets-1036.html</guid>
										<title>1975 - 1982 Corvette:  Service Bulletin:  Viton Accelerator Pumps - Current and Past Models Equipped with Dual and Quadrajets</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-1982-corvette-service-bulletin-viton-accelerator-pumps-current-and-past-models-equipped-with-dual-and-quadrajets-1036.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-filter-usage-and-installation-938.html</guid>
										<title>1982 Corvette:  Service News:  Fuel Filter Usage and Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-filter-usage-and-installation-938.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-engine-coolant-usage-anti-freeze-specs-change-675.html</guid>
										<title>1982 Corvette: Service Bulletin: Engine Coolant Usage Anti-Freeze Specs Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-engine-coolant-usage-anti-freeze-specs-change-675.html</link>
