										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rear-hatch-defogger-circuit-revision-1076.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Rear Hatch Defogger Circuit Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rear-hatch-defogger-circuit-revision-1076.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-hvac-module-service-622.html</guid>
										<title>2005 Corvette: GM TechLink: HVAC Module Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-hvac-module-service-622.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-delayed-accessory-bus-service-information-558.html</guid>
										<title>1991 Corvette: Service Bulletin: Delayed Accessory Bus (Service Information)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-delayed-accessory-bus-service-information-558.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-low-coolant-warning-light-161.html</guid>
										<title>1986 - 1988 Corvette: Service Bulletin: Low Coolant Warning Light</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-low-coolant-warning-light-161.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-manual-update-sec-6d4-spark-plug-coding-chart-530.html</guid>
										<title>1990 Corvette: Service Manual Update: SEC. 6D4 Spark Plug Coding Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-manual-update-sec-6d4-spark-plug-coding-chart-530.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-optispark-distributor-554.html</guid>
										<title>1992 Corvette: Recall: Optispark Distributor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-optispark-distributor-554.html</link>
