<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-foot-operated-windshield-washer-electric-windshield-wiper-1212.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-nylon-headlamp-adjusting-screw-bracket-779.html</guid>
										<title>1958 Corvette: Service Bulletin: Nylon Headlamp Adjusting Screw Bracket</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-nylon-headlamp-adjusting-screw-bracket-779.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-horn-relay-problems-162.html</guid>
										<title>1956 Corvette: Service Bulletin: Horn Relay Problems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-horn-relay-problems-162.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1964-corvette-chevrolet-partsmart-bulb-and-fuse-charts-1088.html</guid>
										<title>1955 - 1964 Corvette:  Chevrolet PartsMart:  Bulb and Fuse Charts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1964-corvette-chevrolet-partsmart-bulb-and-fuse-charts-1088.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-vent-the-window-regulator-motor-993.html</guid>
										<title>1965 Corvette:  Service News:  Vent the Window Regulator Motor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-vent-the-window-regulator-motor-993.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-instrument-lens-cracking-and-checking-1108.html</guid>
										<title>1960 Corvette:  Service Bulletin:  Instrument Lens Cracking and Checking</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-instrument-lens-cracking-and-checking-1108.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1959-corvette-chevrolet-partsmart-distributors-and-starter-motors-1042.html</guid>
										<title>1955 - 1959 Corvette:  Chevrolet PartSmart:  Distributors and Starter Motors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1959-corvette-chevrolet-partsmart-distributors-and-starter-motors-1042.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1955-corvette-service-bulletin-distributor-dust-contamination-782.html</guid>
										<title>1953 - 1955 Corvette: Service Bulletin: Distributor Dust Contamination</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1955-corvette-service-bulletin-distributor-dust-contamination-782.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-directional-signal-malfunction-94.html</guid>
										<title>1959 Corvette: Service Bulletin: Directional Signal Malfunction</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-directional-signal-malfunction-94.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1957-corvette-service-bulletin-v-8-distributor-chart-780.html</guid>
										<title>1955 - 1957 Corvette: Service Bulletin: V-8 Distributor Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1957-corvette-service-bulletin-v-8-distributor-chart-780.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-accelerator-pedal-falls-off-retaining-studs-956.html</guid>
										<title>1960 Corvette:  Service Bulletin:  Accelerator Pedal Falls Off Retaining Studs</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-accelerator-pedal-falls-off-retaining-studs-956.html</link>
