<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-turn-signal-switch-failure-to-cancel-1209.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-news-ignition-pulse-amplifier-sn-c-1-933.html</guid>
										<title>1965 - 1972 Corvette:  Service News:  Ignition Pulse Amplifier (SN-C-1)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-news-ignition-pulse-amplifier-sn-c-1-933.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-parts-and-accessories-bulletin-delcotron-generator-replacement-parts-1007.html</guid>
										<title>1963 Corvette:  Chevrolet Parts and Accessories Bulletin:  Delcotron Generator Replacement Parts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-parts-and-accessories-bulletin-delcotron-generator-replacement-parts-1007.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-muncie-four-speed-transmission-design-change-1072.html</guid>
										<title>1964 Corvette:  Engineering Service Letter:  Muncie Four Speed Transmission Design Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-muncie-four-speed-transmission-design-change-1072.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-corvette-radio-speaker-replace-50.html</guid>
										<title>1966 Corvette:  Service News: Corvette Radio Speaker - Replace</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-corvette-radio-speaker-replace-50.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-inter-organizationl-letter-high-speed-warning-buzzer-deletion-737.html</guid>
										<title>1963 Corvette: Inter-Organizationl Letter: High-Speed Warning Buzzer Deletion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-inter-organizationl-letter-high-speed-warning-buzzer-deletion-737.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-chevrolet-engineering-service-letter-telescoping-steering-wheel-horn-button-cap-liner-no-42-909.html</guid>
										<title>1965 Corvette: Chevrolet Engineering Service Letter:  Telescoping Steering Wheel Horn button Cap Liner - (No. 42)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-chevrolet-engineering-service-letter-telescoping-steering-wheel-horn-button-cap-liner-no-42-909.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-chevrolet-service-news-two-unit-voltage-regulator-diagnosis-and-adjustment-1258.html</guid>
										<title>1963 - 1967 Corvette:  Chevrolet Service News:  Two-Unit Voltage Regulator Diagnosis and Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-chevrolet-service-news-two-unit-voltage-regulator-diagnosis-and-adjustment-1258.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1966-corvette-service-bulletin-temperature-gauge-reading-too-high-77.html</guid>
										<title>1965 - 1966 Corvette:  Service Bulletin:  Temperature Gauge Reading Too High</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1966-corvette-service-bulletin-temperature-gauge-reading-too-high-77.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-chevrolet-partsmart-fusible-links-1139.html</guid>
										<title>1967 Corvette:  Chevrolet PartsMart:  Fusible Links</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-chevrolet-partsmart-fusible-links-1139.html</link>
