<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-holley-carburetors-primary-fuel-inlet-float-needle-sticking-closed-1204.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-chevrolet-technical-test-report-fuel-economy-fuel-injection-vs-carburetion-1183.html</guid>
										<title>1957 Corvette:  Chevrolet Technical Test Report:  Fuel Economy - Fuel Injection vs. Carburetion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-chevrolet-technical-test-report-fuel-economy-fuel-injection-vs-carburetion-1183.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-automatic-choke-piston-inoperative-due-to-carbon-deposits-768.html</guid>
										<title>1957 Corvette: Service Bulletin: Automatic Choke Piston Inoperative Due to Carbon Deposits</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-automatic-choke-piston-inoperative-due-to-carbon-deposits-768.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1958-corvette-service-bulletin-skinner-oil-savers-for-1958-and-older-model-v-8-engines-1052.html</guid>
										<title>1955 - 1958 Corvette:  Service Bulletin:  Skinner Oil Savers for 1958 and Older Model V-8 Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1958-corvette-service-bulletin-skinner-oil-savers-for-1958-and-older-model-v-8-engines-1052.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-technical-information-carter-afb-carburetor-revisions-163.html</guid>
										<title>1962 Corvette: Technical Information: Carter AFB Carburetor Revisions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-technical-information-carter-afb-carburetor-revisions-163.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-identification-1954-camshafts-distributor-gears-camshaft-gears-all-valve-lifters-979.html</guid>
										<title>1953 - 1954 Corvette:  Service Bulletin:  Identification - 1954 Camshafts - Distributor Gears - Camshaft Gears - All Valve Lifters</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-identification-1954-camshafts-distributor-gears-camshaft-gears-all-valve-lifters-979.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-spark-plug-fouling-idle-adjustment-975.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Spark Plug Fouling - Idle Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-spark-plug-fouling-idle-adjustment-975.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-production-information-mandatory-option-469-dual-four-barrel-carburetor-equipment-1143.html</guid>
										<title>1956 Corvette:  Production Information: Mandatory Option 469 Dual Four Barrel Carburetor Equipment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-production-information-mandatory-option-469-dual-four-barrel-carburetor-equipment-1143.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-level-gauge-dipsticks-987.html</guid>
										<title>1955 Corvette:  Service Bulletin:  Oil Level Gauge Dipsticks</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-level-gauge-dipsticks-987.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-fuel-spillage-gas-tank-filler-cap-96.html</guid>
										<title>1961 Corvette: Service Bulletin: Corvette Fuel Spillage - Gas Tank Filler Cap</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-fuel-spillage-gas-tank-filler-cap-96.html</link>
