<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-rattle-from-turn-signal-lever-1202.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-loose-corvette-door-trim-panel-510.html</guid>
										<title>1984 - 1987 Corvette: Service Bulletin: Loose Corvette Door Trim Panel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-loose-corvette-door-trim-panel-510.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-squeak-and-rattle-diagnosis-guide-499.html</guid>
										<title>1991 Corvette: Service Bulletin: Squeak and Rattle Diagnosis Guide</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-squeak-and-rattle-diagnosis-guide-499.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-inflatable-lumbar-seat-repair-on-c4-corvette-498.html</guid>
										<title>Technical Article:  Inflatable Lumbar Seat Repair on C4 Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-inflatable-lumbar-seat-repair-on-c4-corvette-498.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-instrument-panel-left-hand-lower-trim-brake-pedal-interference-304.html</guid>
										<title>1992 Corvette: Recall: Instrument Panel/Left Hand Lower Trim/Brake Pedal Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-instrument-panel-left-hand-lower-trim-brake-pedal-interference-304.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-steering-wheel-removal-504.html</guid>
										<title>1990 - 1991 Corvette: Service Bulletin: Steering Wheel Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-steering-wheel-removal-504.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-s-i-r-system-diagnostic-energy-reserve-module-exchange-501.html</guid>
										<title>1991 - 1992 Corvette: Service Bulletin: S.I.R. System Diagnostic Energy Reserve Module Exchange</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-s-i-r-system-diagnostic-energy-reserve-module-exchange-501.html</link>
