<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-incorrect-song-information-displayed-1185.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-compass-always-shows-north-1259.html</guid>
										<title>2014 Corvette:  GM TechLink:  Compass Always Shows North</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-compass-always-shows-north-1259.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-repeat-dtcs-p2096-and-p2098-1385.html</guid>
										<title>2014 - 2017 Corvette:  GM TechLink:  Repeat DTCs P2096 and P2098</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-repeat-dtcs-p2096-and-p2098-1385.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-techline-infotainment-dvd-software-update-1161.html</guid>
										<title>2014 Corvette:  GM TechLink:  Techline Infotainment DVD Software Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-techline-infotainment-dvd-software-update-1161.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-pi1410a-normal-characteristic-instrument-panel-red-brake-light-intermittently-comes-on-1358.html</guid>
										<title>2014 - 2015 Corvette: Service Bulletin: #PI1410A: Normal Characteristic - Instrument Panel Red Brake Light Intermittently Comes On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-pi1410a-normal-characteristic-instrument-panel-red-brake-light-intermittently-comes-on-1358.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-heated-and-ventilated-front-seats-inoperative-with-remote-start-1265.html</guid>
										<title>2016 Corvette: Service Bulletin:  Heated and Ventilated Front Seats Inoperative with Remote Start</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-heated-and-ventilated-front-seats-inoperative-with-remote-start-1265.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-lap-timer-function-is-missing-from-the-dic-jun-27-2016-1285.html</guid>
										<title>2015 - 2017 Corvette:  Service Bulletin:  Lap Timer Function Is Missing From The DIC - (Jun 27, 2016)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-lap-timer-function-is-missing-from-the-dic-jun-27-2016-1285.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-corvette-radio-control-assembly-replacement-11.html</guid>
										<title>2014 Corvette: GM TechLink Article: Corvette Radio Control Assembly Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-corvette-radio-control-assembly-replacement-11.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-16-na-219-gps-inoperative-red-line-across-gps-indicator-or-the-location-is-stuck-in-warren-michigan-1289.html</guid>
										<title>2016 Corvette:  Service Bulletin:  #16-NA-219: GPS Inoperative, Red Line Across GPS Indicator, or the Location is Stuck in Warren Michigan</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-16-na-219-gps-inoperative-red-line-across-gps-indicator-or-the-location-is-stuck-in-warren-michigan-1289.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-intermittent-loss-of-rear-camera-gridlines-and-or-service-rear-vision-system-message-1310.html</guid>
										<title>2016 - 2017 Corvette: Service Bulletin: Intermittent Loss of Rear Camera Gridlines and/or Service Rear Vision System Message</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-intermittent-loss-of-rear-camera-gridlines-and-or-service-rear-vision-system-message-1310.html</link>
