<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1962-corvette-intake-manifold-casting-numbers-and-date-codes-1179.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</guid>
										<title>1955 Corvette:  Service Bulletin:  New Gasoline Gauge</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-hydraulic-valve-lifter-adjustments-764.html</guid>
										<title>1960 - 1961 Corvette: Service Bulletin: Hydraulic Valve Lifter Adjustments</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-hydraulic-valve-lifter-adjustments-764.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-news-corvette-fuel-injection-760.html</guid>
										<title>1962 Corvette: Service News: Corvette Fuel Injection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-news-corvette-fuel-injection-760.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1958-corvette-service-bulletin-fuel-filter-element-maintenance-777.html</guid>
										<title>1953 - 1958 Corvette: Service Bulletin: Fuel Filter Element Maintenance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1958-corvette-service-bulletin-fuel-filter-element-maintenance-777.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-identification-1954-camshafts-distributor-gears-camshaft-gears-all-valve-lifters-979.html</guid>
										<title>1953 - 1954 Corvette:  Service Bulletin:  Identification - 1954 Camshafts - Distributor Gears - Camshaft Gears - All Valve Lifters</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-identification-1954-camshafts-distributor-gears-camshaft-gears-all-valve-lifters-979.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1958-corvette-service-bulletin-skinner-oil-savers-for-1958-and-older-model-v-8-engines-1052.html</guid>
										<title>1955 - 1958 Corvette:  Service Bulletin:  Skinner Oil Savers for 1958 and Older Model V-8 Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1958-corvette-service-bulletin-skinner-oil-savers-for-1958-and-older-model-v-8-engines-1052.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1961-corvette-service-news-fuel-injection-change-901.html</guid>
										<title>1959 - 1961 Corvette:  Service News:  Fuel Injection Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1961-corvette-service-news-fuel-injection-change-901.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-production-information-mandatory-option-469-dual-four-barrel-carburetor-equipment-1143.html</guid>
										<title>1956 Corvette:  Production Information: Mandatory Option 469 Dual Four Barrel Carburetor Equipment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-production-information-mandatory-option-469-dual-four-barrel-carburetor-equipment-1143.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-holley-carburetors-primary-fuel-inlet-float-needle-sticking-closed-1204.html</guid>
										<title>1966 Corvette:  Service Bulletin:  Holley Carburetors - Primary Fuel Inlet Float Needle Sticking Closed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-holley-carburetors-primary-fuel-inlet-float-needle-sticking-closed-1204.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-connecting-rods-988.html</guid>
										<title>1954 Corvette:  Service Bulletin:  Connecting Rods</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-connecting-rods-988.html</link>
