<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1962-corvette-rochester-fuel-injection-part-numbers-1178.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-pump-suction-pipe-174.html</guid>
										<title>1955 Corvette:  Service Bulletin: Oil Pump Suction Pipe</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-pump-suction-pipe-174.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-speedometer-driven-gear-870.html</guid>
										<title>1958 Corvette: Service Bulletin: Speedometer Driven Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-speedometer-driven-gear-870.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-oil-filler-cap-and-crankcase-breather-1214.html</guid>
										<title>1958 Corvette:  Service Bulletin:  Oil Filler Cap and Crankcase Breather</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-oil-filler-cap-and-crankcase-breather-1214.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-chevrolet-product-engineering-technical-information-spark-plug-electrode-interference-with-piston-1066.html</guid>
										<title>1961 Corvette:  Chevrolet Product Engineering Technical Information:  Spark Plug Electrode Interference With Piston</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-chevrolet-product-engineering-technical-information-spark-plug-electrode-interference-with-piston-1066.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-service-bulletin-calibration-revised-to-correct-lean-condition-at-wide-open-throttle-955.html</guid>
										<title>1959 - 1960 Corvette:  Service Bulletin:  Calibration Revised to Correct Lean Condition at Wide Open Throttle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-service-bulletin-calibration-revised-to-correct-lean-condition-at-wide-open-throttle-955.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-hydraulic-valve-lifter-adjustments-764.html</guid>
										<title>1960 - 1961 Corvette: Service Bulletin: Hydraulic Valve Lifter Adjustments</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-hydraulic-valve-lifter-adjustments-764.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1961-corvette-service-news-fuel-injection-change-901.html</guid>
										<title>1959 - 1961 Corvette:  Service News:  Fuel Injection Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1961-corvette-service-news-fuel-injection-change-901.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1961-corvette-service-bulletin-oil-consumption-complaints-42.html</guid>
										<title>1957 - 1961 Corvette: Service Bulletin: Oil Consumption Complaints</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1961-corvette-service-bulletin-oil-consumption-complaints-42.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-chevrolet-technical-test-report-fuel-economy-fuel-injection-vs-carburetion-1183.html</guid>
										<title>1957 Corvette:  Chevrolet Technical Test Report:  Fuel Economy - Fuel Injection vs. Carburetion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-chevrolet-technical-test-report-fuel-economy-fuel-injection-vs-carburetion-1183.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-production-information-mandatory-option-469-dual-four-barrel-carburetor-equipment-1143.html</guid>
										<title>1956 Corvette:  Production Information: Mandatory Option 469 Dual Four Barrel Carburetor Equipment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-production-information-mandatory-option-469-dual-four-barrel-carburetor-equipment-1143.html</link>
